High Compression 6.0 Build ?'s
Hey guys, im thinking of throwing a motor together for nitrous. How does this sound....
LQ9 Iron Block
Wiseco +12cc Pistons (4.030)
PRC 2.5 LS6 Heads
Custom Grind cam that im unsure of which way to go
Compression should be around 13.5:1
Forged rods/Crank
Single Plane intake
Fast 4 Barrel
Nitrous Outlet spray bar in the intake manifold
Fueled on E85??? (is this possible?)
This will be going in a auto fbody and we are looking to spray a 200-300. Any of this sound out of whack?
LQ9 Iron Block
PRC 2.5 LS6 Heads
Forged rods/Crank
Single Plane intake
Fast 4 Barrel
We put down 530 with Stock Heads (Re-worked by BES) and stock bottom end LQ9. The cam was custom ground and we had to Flycut the pistons for valve clearance.
The 4 barrel TB and Nitrous Outlet custom plumbed intake will be the icing on the cake.
I got a video of the Camaro, I just need to find it...
