66 Catalina GEN IV 5.3/Muncie
Over the past year in my free time I've been working on my friends 66 catalina. The 389 was toast and he wanted to join the LS world with the big boat. Tried talking him out of it, but to no avail the LS was purchased and been chasing my tail ever since.
Got a 2007 5.3 with 60k on it.
And heres what shes going in 66 Pontiac Ventura
Got it torn down and decided to go with a Texas Speed Torquer II cam. Did a full DOD removal, LS2 cam gear up front, LS6 lifters, LS6 Oil pump, LS2 valley cover.
mounts
Fit up to trans to see if there is clearance issues ....
Clears here
but not here....
looks little in that huge hole!
mounts
Clears here
but not here....
Found the steering to be hitting the pan when the engine was in place. Spent some time looking under cars on power tour last year and talking with vendors etc. Came to the conclusion we needed this pan.
Had to notch the crossmember to clear the front of the pan.
Frame boxed in
Engine / trans bolted in place
Harness test fit with 07 Truck fuse block
Brings me up to date. I need to lay under the car and photo the exhaust work done as well as fuel system.
This leads up to the questions. Has anyone used the Gen IV truck fuse block to power the harness as stand alone, like you can the Gen III truck fuse blocks?
This may help you,
https://ls1tech.com/forums/conversio...c5r-427-a.html
I'm still building it, hard to find time to work on it but the motor is running. I'll update it by the weekend.
LS1Tech Sponsor
I'm digging that Pontiac engine color. Nice work.
Jon
PSI
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Ebay Store
LS1Tech Sponsor
Sweet swap!! I really wish GM hadnt done away with Pontiac!
If you decide you dont want to use the factory fuse block we sell a DIY kit that is an assembled factory style fuse block with splash guards and labels the inside. You would have to wire it in to your harness.
__________________
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
1-888-467-4491
Do you have a link or a picture of what your fuse block looks like?
This may help you,
It wont run the same , Im sure you will miss those hard starts , rich gas smells, choke issues , exc exc exc
great choice for a swap it will seriously go from a pain to drive,,,,, to fun
Well considering I havent driven it much in the past 22 years I'll be thrilled to drive it in any condition However I am looking forward to this build!
