tunerpro rt readings. pls help!!!!
Old 03-01-2013, 07:25 PM
teal94z281989's Avatar
Default tunerpro rt readings. pls help!!!!
Can any one tell what is ok and what is not? Im also staying in open loop.
Old 03-02-2013, 06:58 AM
bump. anyone?
Old 03-02-2013, 07:46 AM
BIGCAT7274's Avatar
"this video is private"
Old 03-02-2013, 08:51 AM
Hmmm I wonder Y u can't see it. It uploaded it on YouTube then posted it here. The video should not be private I tried it a couple time and works for me.
Old 03-02-2013, 06:02 PM
Bump.
Old 03-02-2013, 09:40 PM
Alex94TAGT's Avatar
I'll try to get the ball rolling. FYI -- It's easier to analyze if you export a datalog to an excel spreadsheet. Also, take a longer log.
Why have you decided to run permanently in open loop?
Few problems I see:
1) You're getting knock retard at idle. Knock retard should always read 0. This may or may not be related to item #2:
2) Toward the beginning of your video, the O2mV are split -- driver's bank is showing excessively lean, passenger bank is showing excessively rich. Neither seem to be oscillating as they should, so I would assume they are both pretty well pegged into the rich/lean side of their switch-points. However, the left O2 jumped into the 900mV range toward the end of the video. Is the car misfiring at all? It appears that the knock retard went to 0 when the left O2 jumped to 900mV, but I need a longer log to verify. Perhaps a misfire getting picked up by the knock sensor, which would also explain the low O2mV. That's my best guess at this point, anyway.
Narrowband O2 sensors are only accurate within a narrow window around 14.7:1 AFR, so it's difficult to judge the severity of any fueling problem without more information. I'd be able to tell you more if you were running in closed loop, or if you had a wideband.
3) IAC counts are getting a bit low -- I'd probably close your throttle blades a little bit (via the throttle stop screw near the throttle linkage) in order to bring the counts back up. Most n/a guys aim for IAC counts of around 40 at idle. The idea here is that you want to maintain a cushion so that the IAC doesn't bottom out at 0 or max out at 160 (thus losing stability of the control system). Closing the blades will also direct more air through the IAC passages, which can help equalize the idle air distribution between cylinders.
Think that's a good starting point. We'll see what others have to say.
Old 03-02-2013, 09:41 PM
U can watch the video now. I forgot to make it public kinda new at this YouTube stuff lol
Old 03-02-2013, 09:56 PM
I have a longer video I will post. I do not want to run in open loop it is just staying there for some reason an I need it to be in closed. Also I do have a back fire when I drive the car and I get like 8mpg. I believe the O2 sensors are the ones that came with the car which has almost 160K so I'm gonna change them both out next weekend. Also how do I export the data log to a sprees sheet
Old 03-02-2013, 10:13 PM
Alex94TAGT's Avatar
Do you have any diagnostic trouble codes? Has anyone messed around with the tune?
I've never used Tunerpro -- no clue how to export in that program. You can export using Freescan (which is free) or Datamaster (20 free trial logs).
Old 03-02-2013, 10:18 PM
Old 03-02-2013, 10:26 PM
no one has messed with tune. as for trouble codes idk how to pull codes. alls i did was put the engine back together and now its running really rich but idles great and misses a lil when driving also uses tons of gas. I think its my o2s that are just done. Also have a lil chatter from rockers on the passengers side i have to tighten up
Old 03-02-2013, 10:54 PM
Alex94TAGT's Avatar
Haven't looked at your newest video yet, but in response to your post(s):
The noise created by loose rockers / roller rockers can also be picked up by the knock sensor as false knock. I'd definitely get those readjusted, and then see if the knock retard goes away.
Freescan or Datamaster can display diagnostic trouble codes. Download one and try it out. My guess at this point is that you have some codes forcing the vehicle into open-loop mode. Get those straightened out, and you should get back into closed-loop.
If you suspect the oxygen sensors are at fault, go ahead and replace them. Cheapest I've found them is on Amazon -- search for AFS75.
Old 03-03-2013, 09:39 AM
Ok thanks I will download one of them and re-post my results
Old 03-03-2013, 11:54 AM
the only code i get is code 18
Old 03-03-2013, 12:39 PM
Alex94TAGT's Avatar
Ah, now we're possibly getting somewhere.
DTC 18 is an injector circuit failure. That might explain the intermittent lean driver's bank. Do you have a voltmeter with which to test the injector circuit?
If so, ohm out the injectors (all should read 12~15Ω), and test that all injector connectors are being fed +12VDC. The PCM decides when to ground out the injectors, but you can test continuity between the injector and the PCM at least. I can look up the PCM pinouts for you if you wish.
You can use noid lights to inspect injector operation. Another quick test you could do is use an IR thermometer to measure the header primaries. The cold one is a dead cylinder.
[Edit] To be clear, I would probably start testing the driver's side first -- I suspect the problem is on that bank, according to your logs. If you locate a loose connector or something, then reset the PCM (pull the PCM fuse or disconnect the negative battery cable for a while), and run the car again to see if the code recurs.
Old 03-03-2013, 01:35 PM
DTC 18 is an injector circuit failure. IThat might explain the intermittent lean driver's bank. Do you have a voltmeter with which to test the injector circuit?
Ok I will do the test and let u kno what I get. Also will this make me stay in open loop? And should I test while the car is running or just with the key on
Old 03-03-2013, 02:07 PM
Alex94TAGT's Avatar
The DTC 18 is likely what is forcing you to stay in open loop, if that's what you mean.
If you fix the injector circuit and resolve the code, that should hopefully get you back into closed loop.
Depends entirely on what you are testing.
-To test the resistance of the injectors, the car can be completely off. Just disconnect the electrical connectors from the fuel injectors, and probe the two recessed blade terminals within the fuel injector. Be careful not to lose the metal retainer clips on the electrical connectors -- they merely push in with your thumb as you wiggle/pull the clip up and away from the injector.
-To test for +12 VDC at the injector, the ignition key would have to be in the 'on' position. Probe across the '+' terminal of the injector connector and a frame ground (such as the grounding stud on the passenger side inner fender well -- alligator clips help). Note that you cannot merely probe across the two terminals in the injector connector -- the ground wire is only intermittently grounded when the PCM decides to fire the injector.
-To test using noid lights, the car would be running.
-To test header primary temperatures using an IR thermometer, the car would again obviously be running.
There are many ways to test all of this -- you could also carefully supply power and ground to the injectors and see if they make an audible 'click' noise.
Here's a fuel injector circuit diagram. Note that the PCM 'A' Connector is the one labeled Red:
(click for big)
Old 03-03-2013, 03:33 PM
Ok thank u I appreciate the help I will check this out tomorrow since I am not with the car now. And would this resolve my crappy mpg
Old 03-04-2013, 12:15 PM
this is a longer video of freescaner. please let me know what is going on thanks.
Old 03-04-2013, 12:35 PM
avewhtboy's Avatar
It looks like your left O2 sensor is dead, could try swapping them side to side to see if the low numbers follow the sensor.
Quick Reply: tunerpro rt readings. pls help!!!!
