backup camera
Old 03-02-2013, 09:03 AM
cajunss's Avatar
Default backup camera
I'm getting ready to purchase a Kenwood double din unit that is able to hookup a backup camera I figure while I'm installing it I like to see about a backup camera. Just wondering if any you guys installed one in an f body and what did you go with license plate type on the key hole one.
Old 03-14-2013, 10:48 PM
redssmaro's Avatar
id put it in the keyhole. besides the fact that u will get a better view. it would look sick in that location
Old 03-15-2013, 09:03 PM
Blackpanther99's Avatar
Agreed^ That would be the bestest spot IMO.
Old 03-16-2013, 07:26 AM
DaRReLL's Avatar
I was planning the same. Really, when's the last time you used a key to open the hatch?
Old 03-16-2013, 09:45 AM
JOHNNY59's Avatar
if you want a back up camera in your car,buy a mini-van!!!!!(ha-ha)
Old 03-16-2013, 12:19 PM
Daniel Richards's Avatar
NEVER, but that may have something to do with the fact the guy I bought my car from only had the key FOB's and ignition keys. I really need to get some keys made incase I get a dead battery.
Old 03-17-2013, 01:15 PM
JAY-R's Avatar
what kenwood model? I have a Kenwood doulbe din myself and thinking about putting mine in the same spot. keep us updated
Old 03-25-2013, 03:50 PM
TruBloodTransAm's Avatar
PMed you back.
Old 03-26-2013, 06:13 AM
cajunss's Avatar
thanks for the PM. There is not much info on the keyhole cam installs. I found a licence plate cam BOYO VTL375HD seems to have good reviews.
Old 04-11-2013, 09:41 AM
V61ST48's Avatar
I just installed a back-up cam on my bird last night. I went with the license plate cam because that what came with my rearview mirror.
Old 04-11-2013, 12:02 PM
cajunss's Avatar
Which one did you go with?
cajunss's Avatar
Kenwood DNX890HD
Old 04-22-2013, 01:04 PM
V61ST48's Avatar
T-view RV102C.
Old 04-22-2013, 01:34 PM
nitrodude's Avatar
I would do a license plate bracket like the above before removing the keyhole in the back..
My camaro electric trunk popper stopped working for about a week and I had to use the key-Would of sucked if there was no key hole lol.
Old 04-22-2013, 02:15 PM
lemons12's Avatar
I have zero doubts at some point in time you will get stopped for it covering the tags.
Old 11-06-2016, 02:31 AM
Brody Tampa's Avatar
Question, how did you route the wires from the license plate cam into the trunk area? Did you need to drill and where? Thanks! Looking to put mine in soon. Want a clean install
T-view RV102C.
Old 11-06-2016, 05:03 PM
Copy & Paste Moderator
VIP1's Avatar
I have a reverse camera there too. If you follow the brake light wiring, you'll find the existing grommet that they use. I passed the backup camera wire through there. In my case, I needed to lengthen the wires. There is also a box inline that contains a regulator to drop the car's voltage down to what the camera needs. I wanted to keep that and the video connection inside the car so I extended the section between it and the camera.
Old 10-03-2018, 06:02 PM
DABURD's Avatar
Red face
T-view RV102C.
Hi. I'm installing my backup cam and would like to know how you got the wires through the trunk to the license plate please?
Old 10-03-2018, 07:49 PM
VIP1's Avatar
Here is how I did it:
Also, since my camera is rotate-able, I mounted it to the flat area above the license place (where the light is) and rotated the camera body so it still faces rear.
This isn't the exact one I bought, but it looks similar:
Old 10-03-2018, 08:18 PM
DABURD's Avatar
okay, but can you help me with the actual wiring part?
Quick Reply: backup camera
