8.8 rear end swap parts for fbody.......
Category: Drivetrain
Price: $225
Location (State): TN
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6, LT1/LT4, Small Block, Big Block
LS Engine?: Fits LS Engine
i have a explorer 8.8 housing.it has a carrier in it already but its non-posi.you can either buy a 28 spline mustang carrier and use your stock fbody axles.or buy a 31 spline carrier and buy better axles.
i have the fbody axle tubes that are needed.
also included is the hiltsy torque arm mount.hiltsy is a member on here and has a 8.8 build thread.
if you are good with welding and setting up gears you can really save yourself some money........
