Pics of my TSP/Patriot Race port heads
Old 04-20-2004, 01:42 PM
gomer's Avatar
Default Pics of my TSP/Patriot Race port heads
I got these babies back from TSP this past Friday, along with their new "Torquer" camshaft. I will be firing it up tonight and dynoing on Friday. I am VERY impressed at how much different the heads look now The hand finishing is very nice, no CNC marks anywhere. Completely polished thru the intake and exhaust runners, bowls, and even the combustion chambers. The heads have 2.08/1.60 valves, Patriot "GOLD" dual springs, with Super 7 Locks, and Super 7 Lock Ti Retainers. The heads started life as a set of stage II LS6 styles and went off for a little "cosmetic surgery" If you have the LS6 styles, you might want to call Jason or Trevor and see about having your heads upgraded. The turnaround time was very quick!! Thanks again guys for putting up with all my phone calls!!
Old 04-20-2004, 02:00 PM
CHRISPY's Avatar
look very nice
what port volumes? 228 cc?
Old 04-20-2004, 02:02 PM
pdd
pdd's Avatar
wow. those look sweet
Old 04-20-2004, 02:04 PM
gomer's Avatar
Originally Posted by Chris ARE 360
look very nice
They were 225cc intake 83cc exhaust before the polishing, so they are probably just a little larger now. The combustion chambers are 59cc.
Old 04-20-2004, 02:36 PM
Ben01C5's Avatar
Looking forward to seeing your results.
Old 04-20-2004, 02:49 PM
HOSS99's Avatar
Those look good. Do you know what they flow?
Old 04-20-2004, 03:10 PM
Mike K.'s Avatar
Im sure you will see good #s with the heads/compression, plus knowing you Im sure that cam is plenty big. Nice looking heads there, good luck on the new setup. You thinking of getting one of those rumbler exhausts?
Old 04-20-2004, 03:12 PM
TimW's Avatar
What is this "torquer" cam?
Old 04-20-2004, 03:16 PM
30th TA 0219's Avatar
Those heads are ringers!
You need to add 500lbs to your car if you're gonna "cheat" like that!
I just wanted to be first to spout of some of the typical Hater rhetoric!
Gomer, looking good, but screw the dyno, how about some tangible numbers.
Old 04-20-2004, 03:19 PM
gomer's Avatar
I was wondering when somebody was going to ask about that
It has less total duration than the 231/237 I ran a while back...and is just slightly larger than the 230/232 that I just pulled out, I'm done with big cams.. hell, these "baby" cams make good power
Old 04-20-2004, 03:23 PM
Justin99TA's Avatar
My baby 224/228 put 392hp and 427ftlbs to the rollers. Track times will be here on friday
gomer's Avatar
Sorry.. but dyno numbers is what makes me horny I'm afraid to take my car to the track, I'd hate to break something. I'll keep my racing to the "state funded" tracks close to my house that open after midnight I'm going to dyno it on the spray this time too, I've got a small 50hp wet kit that I have used in the past on a certain supra around here, I'd like to see what it is actually giving me to the wheels.
Old 04-20-2004, 07:27 PM
slyws6's Avatar
How much does that 'race' porting cost? I have the Stage III LS6 heads, I'm planning on putting a turbo on my car in the near future and will have to take them off to find a way to lower the compression (hopefully they can open up the combustion chambers).
-Sly
Old 04-20-2004, 08:01 PM
Beast96Z's Avatar
They look like similar to "hand finished" port I got from Patriot. Mine are smooth on the roof, floor, and bowl area. The sides still show a little bit of the CNC. I'd be curious to know how mine flow against yours for ***** and giggles.
Old 04-20-2004, 09:34 PM
Mike98WS6's Avatar
Nice looking set of heads gomer. I can't wait to see what #'s it pulls with them.
Old 04-20-2004, 09:38 PM
I can shift faster than you.
Jason99T/A's Avatar
The heads look real nice Scott! Good luck with the install and let us know how this setup compares to your previous ones.
Jason
Old 04-20-2004, 09:41 PM
Good ol'e County Road 1320 has some of the best dyno tuning stretches anywhere. And every county has one! LOL
CamaroCain's Avatar
if you guys need track results check my sig These heads definately do the job. I have put over 500 miles on them so far and they are doing very well, along with 8 track passes, and more to come soon.
Old 04-20-2004, 09:50 PM
five0killr's Avatar
kick ***!! , seeing those pics just pumps me up even more, ill be seeing my set of these friday or monday, then its time to get greasy,im doing a daily driver set-up with the 231/237, but im still hoping for somewhere close to 450
Old 04-20-2004, 10:03 PM
1BADFNZ's Avatar
yeah i might have to seriously consider those heads
