4l60 vs 4l80
I'm not an expert on the specific benefits of the 4l80e over the 4l60e, but I know the 4l80e is a hell of a lot stronger. but the gearing in the 80 isn't as aggressive and its heavier than a 4l60e.
Everything is smaller on the 60e, when your making big power you need the stronger transmission... IMO
Also the extra weight of the 80e makes up for itself because you can run more power and launch hard off of the transbrake if you have one..
the 4l60e has its time and place depending on your goals...
It really depends on the power level and the power level goal.
I see no reason to swap over to a 4L80E below the 500 RWHP level unless you are going to up the power later.
I'm not one to push the 4L60E unit but it has it's place and being the OEM unit in many GM vehicles, there are times when it's the best unit to use, even when you may be pushing it's limits.
Once you eclipse the 500-550 RWHP level, the 4L80E should be a consideration.
well as of right now its a bolt on car nothing major mostly exhaust. trying to keep the gas mileage ucause its my dd. but when may gets here im pulling it off the road for good. i want a solid transmission thats going to take the punishment when im at the track with is 5-8 times a year for test and tunes, and when im running hondas the street. i have a 408ci from texas speed on the engine stand now. so im hoping after the 4k stall and the 9in rear im around 450rwhp on motor. maybe later a small 75 or 100 shot
