Katech adds two new LS3 crate engines under $10k
Old 03-13-2013, 03:24 PM
LS1TECH Sponsor
Katech_Jason's Avatar
Default Katech adds two new LS3 crate engines under $10k
We are pleased to add two new crate engines to our value line along side our Value 427 LS3. These brand new LS3-based crate engines are available for outright purchase with no core required. They include break-in and validation on our engine dyno.
Torquer LS3
Bore: 4.065”
Stroke: 3.622”
Displacement: 376ci/6.2L
Horsepower: 530
Torque: 470
Redline: 6600RPM
CR: 10.7:1
Block: LS3 aluminum
Crankshaft: LS3 cast iron
Connecting rods: LS3 forged powdered metal with Katech rod bolts
Pistons: LS3 cast hypereutectic aluminum
Camshaft: Torquer LS3
Cylinder heads: CNC-ported LS3
Valves: LS3 hollow stem intake, solid exhaust
Induction: LS3
Oiling system: wet sump
Price: $8,630
Hot Rod LS3
Bore: 4.065”
Stroke: 3.622”
Horsepower: 550
Torque: 480
Redline: 6600RPM
CR: 10.7:1
Block: LS3 aluminum
Induction: Single plane with Holley carburetor
Price: $9,970
Old 06-19-2013, 08:25 PM
etrexny1's Avatar
Interested in the torquer.. does it come with coils injectors sensors?
Old 06-20-2013, 07:05 AM
LS1TECH Sponsor
Yes, it does.
Old 07-08-2013, 11:36 AM
James Linder's Avatar
Default LS3 torquer
I have 2000 SS Camaro. Will the Katech motor work with the OEM PCM or does this have to be swapped out?
Either way, the PCM will need to continue to be able to control the built
4L65E installed in my car.
Does the Katech LS3 torquer come with MAF and throttle body and custom tune for the PCM?
What is delivery time?
James Linder
Bella Vista, AR
Old 07-08-2013, 01:16 PM
LS1TECH Sponsor
James Linder
Bella Vista, AR
Sent email
Old 07-08-2013, 01:18 PM
Dickie-311's Avatar
James Linder
Bella Vista, AR
i'm also curious I have the same year car
Old 07-08-2013, 01:28 PM
LS1TECH Sponsor
I'll answer it publicly then.
James Linder
Bella Vista, AR
We can make it run on the OEM PCM with a trigger swap or if you use the Lingenfelter converter box.
We don't sell the engine with a PCM, MAF or tuning. That will need to be done by the installer.
Delivery time is about 3-4 weeks.
Old 07-08-2013, 08:28 PM
MUFFINMAN89's Avatar
Awesome
Quick Reply: Katech adds two new LS3 crate engines under $10k
