Rear Lower control arm play
Old 03-13-2013, 05:19 PM
White6SpdZ28's Avatar
Default Rear Lower control arm play
So wondering if my rear LCA bushings are bad. I have play if I grab the LCA and push and pull it (As in from passenger side to drivers side) I would say its probably about 1/4" total play. Thanks
Old 03-14-2013, 08:55 AM
LS1Tech Premium Sponsor
BMR Sales2's Avatar
What kind of LCA is it, factory or aftermarket?
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old 03-14-2013, 09:28 AM
Factory
Old 03-14-2013, 09:38 AM
BMR Sales2's Avatar
It sounds like the factory rubber bushings are just allowing more movement than they should. More than like it is probably just wear and tear from age. If you are looking for something to minimze the movement I would just go with a good quality set of aftermarket non-adjustable tubular lower control arms like our BMR TCA001, they are very affordable and perform amazingly well.
BMR non-adjustable LCA (TCA001)
__________________
Glenn ***
Sales Tech
813.986.9302
Old 03-14-2013, 10:38 AM
Thought has definitely crossed my mind.
Old 03-16-2013, 11:35 PM
Zlow28's Avatar
they must be pretty worn out if they have 1/4" of play. When i replaced mine, they were pretty solid in there. Id recommend buying new ones and youll feel a difference.
Old 03-17-2013, 12:08 AM
Thanks guys, I'm just going to price out new LCA's.
Old 03-17-2013, 03:25 AM
Spartan7's Avatar
The whole rubber part of mine had separated from the outer metal sleeve, they were toast. I replaced them with some Moog bushings.
Quick Reply: Rear Lower control arm play
