Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Steering wheel swap
Old 03-15-2013, 08:44 AM
bluemilew's Avatar
Default Steering wheel swap
Tried to find information, but was having trouble finding anything about people switching out the bus-sized steering wheel in their V. I have an OMP 330mm suede wheel left over from my old car, and want to swap it over.
-Is the hub the same as another GM model, like a vette? Can't find a CTS specific adapter. Spline count?
-Airbag resistor? Not a deal breaker, but not having a light on the dash is nice.
-Ideas for switch relocation? I may move the cruise control to ashtray, but I don't really use the left side buttons. I can always turn off TC from the glove box, yes?
I've seen V1's with roll bar/aftermarket seats, so I hope someone has done this already and knows this stuff. Thanks!
Old 03-17-2013, 07:03 PM
Junior-1's Avatar
Replaced the upper shaft with a C5 Vette one...
Better pic
I moved to toggle button from the wheel and mounted them down near the shifter to cycle the gauges
Old 03-17-2013, 07:18 PM
FuzzyLog1c's Avatar
No SRP pedals on that setup?
Old 03-17-2013, 07:25 PM
Junior-1's Avatar
Probably do something of the like in May
Old 03-17-2013, 07:55 PM
FuzzyLog1c's Avatar
Well, for what it's worth, I'm loving their block setup (picture). The gnarlier pattern has a great feel--no slippage with everything from gym shoes to dress shoes. The wider gas pedal helps with heel-toe.
Old 03-19-2013, 09:28 PM
bluemilew's Avatar
Sweet! You mean just the steering hub, not the whole upper shaft correct? Also, which brand of hub did you use?
Old 06-30-2013, 10:01 PM
bluemilew's Avatar
Update:
I finally got around to doing my custom gas pedal extension and pulled my steering wheel. It turns out that the splines are the same dimensions as a miata, which worked out great since I had a hub adapter sitting around already.
Next is getting a resistor to turn the airbag light off, and deciding if i want to keep/relocate the cruise control switches. Pics to come in the next few weeks probably, at the pace I am working.
Old 06-30-2013, 10:19 PM
UnsafeAtAnySpd's Avatar
Keep us updated. I've been thinking about ditching mine.
Old 07-01-2013, 08:45 PM
meatyCTS-V's Avatar
Originally Posted by bluemilew
Update:
Miata *** checking in,
Sounds like a good deal, I've got plenty of Miata crap laying around lol
This is awesome to know!
Old 07-02-2013, 08:09 AM
jclayc's Avatar
the airbag codes are easy enough to turn off after adding the resistors
Old 07-08-2013, 09:35 PM
bluemilew's Avatar
I really need to buy a camera. For now here's a teaser.
Is the resistance needed for airbag the same as other GM models? I have read a bunch of different values, and a whole lotta guesses. There are two airbag connectors too I guess..
Old 07-09-2013, 09:03 AM
jclayc's Avatar
I think I used 2.7 ohm resistors - 2 needed per seat.
you could also buy a rheostat at RadioShack if you want to dial up until you find the precise resistance you need and then buy regular resistors at that value
also, if you pull the passenger seat, you'll throw a Passenger Presence System code unless you keep your stock seat's PPS or figure out how to bypass it (I'm still working on that)
Old 12-22-2013, 01:05 PM
right_on's Avatar
what year miata steering wheel adapter did you guys use? i'm about to ditch mine. thanks!
Quick Reply: Steering wheel swap
