Clutch suggestions
Clutch suggestions
Currently running a spec 3+ in my 99 TA... its practically new but slipping currently at my low boost/pump tune which makes 800whp... this is the only thing keeping my from turning up things a little ... i would like suggestions on a good multi-disc clutch to go with that will support a **** ton of power. Ive been looking at the Mcloed Twin but it says it will handle 1k whp, which is probably around the power level my car will be sitting at on higher boost and I don't want to be pushing the limits of whatever clutch I decide to go with... any opinions are appreciated..
and yes, im considering going auto just dont know when that will be...
Look into our Twins and Triples
Twins-
Level 2-1000 rwhp/tq
Level 3- 1500 rwhp/tq
Triples-
Level 1 Triple- 1000hp
Level 2 Triple- 1500hp
Both offer excellent capacity, great driveability. All of our twins/triples use a billet cover, everything is made in the U.S. If you have any questions give us a call at 817-750-2000
Id like to see you get a clutch that will hold and turn it up.... Way up
Twins-
Triples-
Hey Speed I would be interested in knowing more about your current setup and situation. Specifically, what your torque output is. What flywheel is being used? Where engagement occurs relative to pedal travel. Etc... Give me a call at your convenience.
