Ported TB
Ported TB
Who will port just a TB?
I'm buying used AI 200cc CNC heads for my 355 build and getting my intake ported to match them. I talked to AI and they won't port my TB. I was wondering if anyone else would do just the throttle body alone? I know some will do it with the intake.
Would it really not matter? I know it takes a lot to NEED a bigger throttle body. But wouldn't I see good gains if I could get it at a good price? (I don't know what that price is, hence my questions). I also have 30 lb injectors I plan on putting on there.
Why is everyone still asking this question.
A 355 with 100% VE at 8000 rpm consumes 810cfm.
Stock TPI/LT1 48mm Throttle Body w/o airfoil -- 783.0 cfm
(Reported from a flow test)
You are not going to achieve 100% VE. Its possible but unlikely.
So say you're at 90% VE and spin it to 7000rpm (LT1 PCM limit).
Thats 647cfm roughly. Even at 100% VE 7000rpm is 720cfm.
As you can see the stock TB will support you're goals.
When the engine vacuum draws air in, if the velocity is higher it will help draw in more air, this is the principal on why a headers and x pipes work.
But there has to be a balance.
