Oil Pressure after H/C
Alright guys so I have a 97 z28. I recently completed an engine rebuild. While I had it apart I installed a cc503 cam, supporting valve train, LE1 heads, 36# FAST injectors, and a tune. Before the build I had no problems with oil pressure. Afterwards, it's flooding like a mother effer. On cold starts it holds 40psi, until it warms up, after that I have around 20psi while driving, and pretty damn close to the red line when in park. The first time I changed the oil it was full of gas. Since then I've changed the oil 3 times and it seems like there is less gas in the oil everytime, but it's still enough to cause a fuel smell and thinning out my oil enough to where I don't have the correct oil pressure. I've checked FPR, and leaky injectors, oil pressure sensor on the intake. Any ideas on what it could be, I'm tired of chasing this problem!
if it is overfueling that bad the cylinders could already be wiped.
Did you do something foolish like neglect to hook the vacuum reference for the regulator back up? Guys have lost engines to that mistake before.
How about the tune, just because you paid for a tune doesn't mean it was done right.
Did you verify the received injectors were the size you told the tuner?
So you ran the car with 36# injectors without tuning for them first? How long? I'm kind of surprised it ran with that much extra fuel. If this is what you did, it sounds like it is time to hone it and ring it at minimum.
Village Troll
Yeah running a larger injector where the PCM has not been tuned for it is a real bad thing. Don't run the engine any more until you can get it tuned, or put the stock ones back in. Honestly, IMO the stockers should be about all you need for that setup. Do a compression check/leakdown as well to see if your cylinders haven't been washed out.
do not drive it till you get the fuel in the oil thing fixed regardless of what it is.....fuel in bearings is not good not to mention your washing down the walls and you will possibly start to encounter ring issues.......the low oil pressure is more than likely from the viscosity of the oil being reduced from all the fuel in the oil....fix it before you are ripping the whole motor apart
