shaved 5.3 head questions
Old 04-06-2013, 09:28 PM
camarozz383's Avatar
Default shaved 5.3 head questions
hey guys what is the maximum i could shave my 243 5.3 heads to bump up compression?
Old 04-07-2013, 05:35 AM
nothing?? I know someone knows something
Old 04-12-2013, 02:30 PM
LS5.3stang's Avatar
i wouldnt go over .040 you will have intake alignment issues.
Old 04-29-2013, 06:23 PM
Default shaved 5.3 heads
got to be someone who knows a more concrete answerwhat is the most i can shave while using GM 5.3 mls gaskets with the cam specs below? thanks
2008 5.3
243 heads
cam 219/233-553/536 109 lobe separation
edelbrock intake
MSD 6LS2 ignition
750 holley carb
Old 04-29-2013, 06:24 PM
anymore info? thanks
Old 04-30-2013, 06:35 AM
To the top
Old 05-07-2013, 04:20 PM
slowbu's Avatar
I want to know to on this I'm doing a carb 5.3as well an want to know the max on shaving the heads
Old 05-08-2013, 08:01 PM
Quick Ranger's Avatar
I would measure ptv clearance before milling the heads, then you will know what you can mill them to.
Quick Reply: shaved 5.3 head questions
