ARP crank bolt stripped/damaged threads
Old 04-08-2013, 09:19 PM
jlee29's Avatar
Default ARP crank bolt stripped/damaged threads
I removed my ARP crank bolt and the end threads were damaged. Im not sure if the threads inside my crank are messed up as well? What would you guys suggest? I have two new TTY GM stock bolts laying around, I could use them and see what happens. Maybe I'll take my old TTY bolt cut a cleaning grove like you do when cleaning head bolt holes out and see what I come up with. Thanks.
This bolt was only use one time.
IMAG1173 | Flickr - Photo Sharing!@@AMEPARAM@@http://farm9.staticflickr.com/8262/8632601761_64294cd2c2_m.jpg@@AMEPARAM@@8632601761@@AMEPARAM@@64294cd2c2 IMAG1173 | Flickr - Photo Sharing!@@AMEPARAM@@http://farm9.staticflickr.com/8262/8632601761_64294cd2c2_m.jpg@@AMEPARAM@@8632601761@@AMEPARAM@@64294cd2c2 by jakelee29, on Flickr
IMAG1171 | Flickr - Photo Sharing!@@AMEPARAM@@http://farm9.staticflickr.com/8109/8632603011_b384fe05fe_m.jpg@@AMEPARAM@@8632603011@@AMEPARAM@@b384fe05fe IMAG1171 | Flickr - Photo Sharing!@@AMEPARAM@@http://farm9.staticflickr.com/8109/8632603011_b384fe05fe_m.jpg@@AMEPARAM@@8632603011@@AMEPARAM@@b384fe05fe by jakelee29, on Flickr
Old 04-08-2013, 09:21 PM
jlee29's Avatar
Sorry guys when I preview the post the pictures are embedded, but once i post it they are not. This is the second time thats happened. I'm not sure why the forum isnt supporting Flickr photos.
Old 04-08-2013, 10:28 PM
badazz81z28's Avatar
That's odd...What part # did you use? LS1? or LS7?
Old 04-09-2013, 07:02 PM
jlee29's Avatar
Ls1 part # on a LQ9. I used it for about 2k miles on one motor and just went to re install it on another and it did this.
Old 04-21-2013, 08:34 AM
jlee29's Avatar
I ended up taking an old crank bolt and gringing grooves down it like what you do with head bolts. After a few passes throught the crank it cleaned everything right up.
Old 04-23-2013, 05:46 AM
01ssreda4's Avatar
I assume you used a longer bolt to install your balancer.
Old 04-29-2013, 10:29 AM
jlee29's Avatar
No I just used an old stock TTY bolt, I hit the balancer with a dead blow hammer to get it started and to be able to grab some more threads. Next time I would probably just get a longer bolt, if I can find one.
Old 05-02-2013, 03:37 AM
01ssreda4's Avatar
The way you did it and the longer bolt are both the wrong way to do it. Glad you ain't working on my engine.
Old 05-02-2013, 03:44 AM
lemons12's Avatar
Can't see pics from phone.. Are you not curious what caused the issue?
Quick Reply: ARP crank bolt stripped/damaged threads
