Hard line pressure rating
Old 04-14-2013, 06:21 PM
mjollnir's Avatar
Default Hard line pressure rating
I ordering fuel lines for my project C3 corvette with a LQ4.
I have a Walbro 255 pump (http://www.summitracing.com/parts/vpn-gsl392)
This pump is rated 60 psi max
I was about to order this tubing for the fuel feed: http://www.jegs.com/i/JEGS-Performan...15101/10002/-1
But then I noticed it is rated up to 25 psi.
This another one is rated 35 psi: http://www.jegs.com/i/Moroso/710/65340/10002/-1
Again, not enough to match my Walbro rated at 60 psi.
So what tubing should I buy? Should I go braided all the way from pump to fuel rail?
Old 04-15-2013, 06:27 PM
mjollnir's Avatar
No idea guys?
Old 04-17-2013, 07:49 AM
ss1
ss1's Avatar
I didn't realize the aluminum tubing was tested to such a low pressure. I imagined it was much higher and OK for use with fuel injection.
Fwiw, a while back I remember somebody mentioned using aluminum tubing with AN fittings and the tubing started to leak after a while. Not sure what the deal with that is.
Old 04-17-2013, 08:04 AM
ss1
ss1's Avatar
Here it is...
https://ls1tech.com/forums/fueling-i...lb-system.html
Old 04-17-2013, 09:01 AM
mjollnir's Avatar
Thanks for input
I'm going for 304 grade stainless steel rated well over 1000 psi. Single Flare 37° as used in high pressure industry and AN fittings
This article helped me much:
http://www.hotrod.com/projectbuild/f...s/viewall.html
You can find 1/2" 50 feet rolls for less than 80 bucks, could do a few cars with that
Old 04-20-2013, 04:00 PM
stevieturbo's Avatar
I used this, it's rated to 250psi. That said, over the years it has been on my car, it has developed pinholes in 2 places that needed repaired. This was with no external marks or damage to the pipe. Would struggle to recommend any alloy line again, although it is still on my car.
http://www.russellperformance.com/mc/fuel/lines.shtml
Teflon lined hose is only really needed if the lines run inside the car.
Old 04-21-2013, 08:31 AM
Old Geezer's Avatar
"Teflon lined hose is only really needed if the lines run inside the car."
Or, if you don't want the garage to stink like fuel...................
Old 04-21-2013, 01:36 PM
mjollnir's Avatar
Yeah Stevie I read some horror stories about aluminium leaking, especially at flares. I guess it's too soft
lol geezer
Old 04-21-2013, 01:53 PM
In my case it was on a straight section. The only common thing in both leaks, was it occurred right at a rubber P-clip that was securing the pipe. Which made even less sense.
Quick Reply: Hard line pressure rating
