p0336 need help
Old 04-15-2013, 09:55 AM
nater36's Avatar
Default p0336 need help
Had a shop change timing cover gaskets and oil pan gasket. Now code p0336. High idle at 0mph. Runs real lean at wot. They put a new accel opti in. I recently changed to richporter opti hoping to fix the issue. No help. Changed crank sensor. No help. Also changed ignition module. No help. 96 firebird formula. 6 speed.
Old 04-15-2013, 10:14 AM
djjab57's Avatar
Check the TPS its what controls the idle
Old 04-15-2013, 10:59 AM
shbox's Avatar
Was there no P0336 before the timing cover/oil pan work? Maybe they did not put the reluctor back in. High idle could be a vacuum leak.
The TPS does not control idle. The IAC does.
Old 04-15-2013, 11:17 AM
Village Troll
SS RRR's Avatar
I have found if the TPS is out of whack it will influence idle. That was with an adjustable TPS though...
Old 04-15-2013, 11:35 AM
nater36's Avatar
Well I would assume vacuum leak or tps but it idles normal while coasting with the clutch pressed. Tps voltage is smooth as butter and shows 0% on autotap datalogger. I can't see iac steps though on the datalogger
Old 04-15-2013, 12:27 PM
nater36's Avatar
Would the reluctor missing cause these issues?
Old 04-15-2013, 12:44 PM
shbox's Avatar
But it does not control it as was stated. If the reading was so far out that the engine thought there was more throttle, then it might cause a fueling change.
OP you might have more that one thing going on, given that there was recent work done on the car. The crank sensor won't [shouldn't] affect performance.
Old 04-15-2013, 12:54 PM
djjab57's Avatar
You are correct as always, I had a brain fart
Quick Reply: p0336 need help
