Highest compression you can get away with on stock LS3?
Old 04-19-2013, 12:26 PM
0verkill's Avatar
Default Highest compression you can get away with on stock LS3?
What's the highest compression you can get away with on a stock LS3? Using 93 octane, at sea level.
Old 04-19-2013, 02:13 PM
newschool72's Avatar
A stock LS3 has 10.7. Are you talking about shaving the heads? As far as LS engines in general, Ive heard of guys getting away with close to 12 to 1 WITH a spot on tune.
Old 04-27-2013, 01:45 AM
gnx7's Avatar
LS1Tech 20 Year Member
bigger cams allow for more compression also.....
You can run 11.25-11.5:1 on 91 octane.... so I would say close to 12:1 as well with 93.
Old 04-27-2013, 08:56 AM
litle88's Avatar
I'm stroke at 12.2 but I have a big cam to bleed it off a Lil on 93 octane.
Old 04-29-2013, 08:11 AM
WKMCD's Avatar
It's a balancing act with the LS3 heads. Too much CR and you can't crank in enough timing to make power. I ran 12:1 and could only run 24-25 degrees of lead. At 11:4, I ran 29 degrees and made more power. These heads LOVE timing.
Quick Reply: Highest compression you can get away with on stock LS3?
