Brake bleeding for 4th gen with Traction Control
Old 04-21-2013, 06:12 PM
zfastss's Avatar
Default Brake bleeding for 4th gen with Traction Control
I'm getting ready to change out my brake fluid in my SS and was checking out the GM service manual and they give a procedure that is different than what most people on here say to do.
I've read that most people start at the furthest point away from the master cylinder and move to the closest point, and this is what the GM manual says for cars WITHOUT Traction Control:
Right Rear->Left Rear->Right Front->Left Front
The GM manual says for cars WITH Traction Control:
Right Rear->Left Front->Left Rear->Right Front
Anybody know why there is a difference?
Thanks
Old 04-22-2013, 02:43 AM
transwiz's Avatar
I also would like to know this one.
Old 05-05-2013, 01:17 PM
JabberJaw's Avatar
Thanks
You can check out the links below. Although I have no experience with bleeding brakes with the traction control system, it was suggested that the T-100 tool is used to exercise the solenoids during the bleeding process.
I believe the traction control system not only restricts accelerator peddle movement but also engages the brakes for the wheel that is slipping.
http://www.ls1.com/forums/f6/bleedin...trans-am-4513/
http://www.ls1.com/forums/f6/another...d-system-3958/
Old 05-08-2013, 02:31 PM
Trunion King
bene's Avatar
I did my brakes a while back and I bled my brakes like a normal or traditional "non-traction" equipped car. I did the same way with my G35 as well and it has a traction control as well.
Old 05-08-2013, 05:09 PM
libertyforall1776's Avatar
Here's an alternate idea:
http://blog.blackdogspeedshop.com/20...-made-easy-er/
Old 05-08-2013, 08:40 PM
Kleeborp the Moderator™
MeentSS02's Avatar
At the end of the day, the order doesn't really matter.
Old 05-09-2013, 09:39 AM
1 FMF's Avatar
on either system the lines get split at the abs modulator. for a traction control car you have 2 separate lines from the abs going to the rear. for non tc only one line that goes to a T fitting on the rear axle and splits to each rear wheel.
for anyone that says order matters i would like to hear a logical explanation of why. otherwise it's one of those things some dumbass said years ago for whatever reason and has been perpetuated thanks to the internet.
Old 05-10-2013, 11:37 AM
MeentSS02's Avatar
The only explanation I've ever heard was that if you start the furthest away from the ABS block and work your way toward it, it might save you some brake fluid when doing a flush. Once I crack open a can of brake fluid, I'm pretty much going to use it all, so I never really cared.
Quick Reply: Brake bleeding for 4th gen with Traction Control
