98 Z28 Y3f 66kmi Clean!
Year: 1998
Make: Chevrolet
Model: Camaro
Price: $16000
Mileage: 66308
Private or Dealer Listing: Private Listing
Location (State): NE
Color: Red
Transmission: Manual
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
It has a iron 6.0L stock bottom end. has melling pump, ls2 chain, gm hott cam with hardened pushrods, and comp 918 springs. has ls6 intake and 853 casting heads and a lil chamber work with ls9 head gaskets. was gonna spray but never did lost interest.spec 3+ clutch
car has Bmr K member, and extreme duty torque arm. spohn adjustable lower control arms and car has been mini tubbed. We moved the inner frame rail in and smoothed it. Removed Bump stop, has adjustable upper perch and 120lb springs in the rear car is scaleable and ride height is adjustable all 4 corners. qa1 coil overs upfront single adjustable. car can do 1.5 60 ft's on street tires. 1.2 on slicks maybe quicker but I didn't have the hp to leave any harder. I used to run a 28x11.5 hoosier et street. on a 10in neutral offset rim (Chevelle offset). when it had a narrowed 9" cut 2.5 off ea side. Had plenty room for tire to grow.
Rear end is a gm 10 bolt with 390 gear, detroit cltchless posi, and alloy axles and a girdle.
Car has a 6pt cage back seat is there for looks. no seatbelts back there. so Total sleeper. Is very streetable! any ?'s feel free to call/ text. 402853three seven69 jeff
for additional pics i can email having trouble up loading them jeff@lsxautomotive.com
Car is on ebay if you search 98 z28 it pops right up if your interested
i call BS i make about 300+ rwhp than you and cant 60 ft anywhere near a 1.20 hell 9-0 cars 60 a 120! best ive done is 1.51 thats off a trailer and i may have a few .0xx in it and thats all.. with a 12 bolt! bro whoever is telling u this info or if you are assuming it all your doing is ruining any kind of credibility you have and its prob hurting your sale! just sayin! o and btw thats with ET STREETS not a radial!
