tune for stock lq4
tune for stock lq4
I just recently put a lq4 6.0l into my s10 Offroad truck, and I have read that a lot of can be power gained on these engines with a tune. The engine internally is stock. It has ls1 exhaust manifolds, a very free flowing exhaust, electric fans and a cold air intake kit. Since the engine is basically stock, what are my best options for tuning? Sorry for the newbie question, I know a dyno tune would be best, but I don't know if the expense is worth the gain on a stock engine
I should add that i would not be doing my own tuning, so handhelds and full suite programers are out. but what about mail order vs in person tunes? I would like to still run my engine on 87 octane. Would the potential gains be worthwhile on my engine?
Planning or carrying more fuel isnt the issue, but sometimes stuff happens when your 4wheeling in the middle of nowhere, and the only fuel you can readily get is 87. relying on 93 octane fuel would be a lack of planing
Stock LQ4 has 9.4:1 CR, it is possible to use 87 octane with a tune. Just keep the low octane table and make sure the knock sensors are good.
As long as you don't go WOT or tow a lot of weight when using 87, you should have no issues.
So you think a tune is only a HP number? There is a whole lot more you can do to a stock truck tune that has no bearing on a HP number but sure makes them drive better. On 87 octane.
And I guess it depends on what the tuner is charging. People spend $300-$400 for handhelds that don't do squat.
I'm assuming you don't have HP? I have a sweet program for a lq4 but it is a 93 octane table. I could pull some timing out for you though. Right now its like 32* and runs like a scalded dog to 6900.
I didn't say you can't, of course you can under the right circumstances.
But I have seen stock LQ4s knocking like a diesel with 87 and tunes so hacked I'm not going to advice someone to race his engine with 87 with a unknown tune and unknown circumstances.
If you want to, go ahead.
