Anyone know where to get 1/2" NPT tap?
I bought mine and the correct bit for the tap from Amazon. Only took a few days to recieve it. only problem i had was my drill wasnt big enough for the bit. had to use my buddies drill press. My drain is in my timing cover.
Incorrect. For what it's worth my $9 NPT 6 piece tap and die set from HF (Even came with a nice wooden storage box) has tapped approx 100 different pans/water pumps and turbo piping with no failures whatsoever.
Ridgid makes one Ive tried a few of the cheaper ones and they suck.
http://www.ebay.com/itm/Ridgid-35830-Model-E-5115-1-2-NPT-Pipe-Tap-Hand-Use-/370528712254?pt=LH_DefaultDomain_0&hash=item56453b763e
Well that sums up that debate whether or not the cheap ones suck. They may be worse if your using them in steel but aluminum is so soft I don't see it dulling a metal tap too quickly.
FYI: My local Napa stocks them(I have bought 2)
The Balkamp manf# p# is "T-304" 1/2" - 14 NPT (on box)
On website it is "BK t304" Napa online price is $17.34
The hard part for me was getting the proper drill size which is 45/64"
Good Luck
Good Luck
For anybody else looking, www.mcmaster.com has anything you need like that and in different quality/price levels.
