I just need help in general haha
Old 04-30-2013, 02:21 PM
01_catfishss's Avatar
Default I just need help in general haha
Ok I bought an 01 SS with the cast iron block swap. Forged internals and the only thing I know about the heads and cam is that they were built as a set and the cam is a 117 LSA. My compression is 8.1 to 1 (built for boost). But the exhaust is long tube true dual all the way out with a resonator at the back, it's a t-top car so it's cracking and junk like that. First question is there a certian exhaust setup I need to put all of the subframe connectors on the car and will I lose any power with it
Old 04-30-2013, 05:43 PM
Jay-P's Avatar
So you are saying that you dont have room for subframe connectors because of the true duals? Are you sure they wont fit?
Old 04-30-2013, 05:57 PM
I'm asking if anyone has both and if they fit before I spend money on a new exhaust that won't fit. The guy I bought the car from lowered the car 2" and the long tubes are broken at the collector. And I figured I'd put either an x pipe or h pipe on to regulate back pressure to gain a little bottom end torque
Old 04-30-2013, 06:08 PM
joker_01z28's Avatar
I have long tubes-3 inch dual set up and spiral flows dumped at the rear, I bought umi bolt in tubular connectors and fits fine. hope that helps
Old 04-30-2013, 06:24 PM
We're you able to go over the rear axel with it or did you have to go under it? And does it scrape everywhere?
Old 04-30-2013, 09:35 PM
Jay-P's Avatar
He has it exiting or "dumped" before the rear end, so neither over or under.
Old 05-01-2013, 08:11 AM
00ZNewb's Avatar
i have 3 inch full duals, and founders performance sub frames. my exaust is no where near the sfcs.
Mine is also dumped at the rear. car isnt lowered, and i still have to be careful of dips and humps, but my borla mufflers are hooj.
Old 05-01-2013, 01:24 PM
Blackpanther99's Avatar
You shouldnt have any issues fitting the SFCs on with true duals. A lot of people run true duals and have 0 issues.
Old 05-09-2013, 02:50 PM
Pseudonym's Avatar
I have 1-7/8 Kooks long tube headers, kooks 3 in true duals that exit at the stock location, and umi 3 point subframe connectors. That is on a trans am that was lowered about 2 inches. You dont need to change the exhaust to add the subframe connectors.
Quick Reply: I just need help in general haha
