4" Cutout Availability, might have to go 3.5"
Old 05-01-2013, 06:17 PM
Tally TransAm's Avatar
Default 4" Cutout Availability, might have to go 3.5"
does anyone know where to get an inexpensive 4" cutout
found a bunch of 3.5" but the only 4" that I have found is a Quick Time stainless that is stupid expensive. not looking for stainless and not looking at that pricing point
trying to put a 4" after the downpipe before it necks into a 3" catback, but looks like it might be a 3.5"
Old 05-01-2013, 06:29 PM
Blackpanther99's Avatar
Other than QTP you can check on Ebay for lower prices or simply look into DMH cutouts. Summit Racing also. Are you looking into getting a electric motor cutout? or just the cutout pipe?
Old 05-01-2013, 06:45 PM
Ferocity02's Avatar
Hah... I just bought the QTP 4" one because I couldn't find another that was much cheaper. And Summit ships to me pretty quickly.
Old 05-01-2013, 07:13 PM
Slow94Formula's Avatar
I've been liking my 4" badlanz pretty well.
Old 05-01-2013, 07:18 PM
just a standard cutout, not electric. was thinking dynomax, flowtech, summit, jegs, etc but they all stop at 3.5"
Old 05-01-2013, 07:23 PM
ill check them out, thanks
Old 05-01-2013, 07:26 PM
Didn't realize you weren't looking for an electric one. They might sell the pipe alone though. Otherwise if it came down to it you could probably make your own I would think.
Old 05-01-2013, 08:41 PM
T/ALT1's Avatar
Here is the one I am going to buy for my setup. http://compare.ebay.com/like/390571395820?var=lv&ltyp=AllFixedPriceItemTypes&var=sbar
It's 4" and only $88 from EBay and its a manual one so Ill just run my down pipe off the 4" side and shrink it down to 3.5" for cruising. Then at the track just open the cutout.
Old 05-01-2013, 08:45 PM
yelo04goat's Avatar
badlanz price is nice! thanks found this useful i wanted a 4'' e-cutout
Old 05-01-2013, 10:10 PM
Originally Posted by T/ALT1
Here is the one I am going to buy for my setup. QTP Exhaust Cutout Manual Stainless Steel Polished Clamp-On 4" Diameter Each on eBay!
I, myself, like the price of $45 much more than $88.
4.0 inch Custom Y-adapter
or the stainless version for $50
4.0 inch Stainless Y-adapter
Old 05-01-2013, 10:29 PM
SPRAYED 01's Avatar
I have a brand new qtp 4inch electric cut out with ss y adaptee,switch,wiring $230 shipped
Old 05-01-2013, 11:35 PM
Nitroused383's Avatar
The qtp y pipe for cutout is only around $45 and its ss. . I went with a 4" from Jegs or summit I cannot remember but it was alumnized steel and only around $30. I had to spend a lot of time modifying it because there was a lot of pipe overhang where they welded it together. Not fun at all. I went with the DMh electric cutout but took it off because it started leaking and rattling real bad.
Old 05-01-2013, 11:58 PM
Wow I breifly checked eBay and prices have gone way up in the last 2 years.
Old 05-02-2013, 12:22 AM
rotary1307cc's Avatar
i am trying to find a 5" and i think raceready is the only one of those available $$
Old 05-02-2013, 12:26 AM
yelo04goat's Avatar
i think i seen one on the badlanz site...
Old 05-02-2013, 01:18 PM
Compressor Surge's Avatar
Here you go.
http://www.badlanzhpe.com.webshop3.a...e0d1f1d3af263e
You guys with the Badlanz stuff...keep them far enough away from the turbo...I fried my 4" electric cutout a couple years ago from excessive heat. Granted it was only like 12-16" off the turbine outlet due to packaging constraints
Quick Reply: 4" Cutout Availability, might have to go 3.5"
