Car Craft LS cam test
Car Craft did a real nice cam comparo this month of factory cams in a 5.3 test mule. The 5.3 was stock including the lm7 cam and the Holley EFI. Pretty suprising results.
I think they have the ls6 cam specs incorrect????
lm7 cam 190/191 .466/.457 116lsa
353hp/5200
384tq/4300
ls1 cam (early) 202/210 .496/.496 116lsa
382hp/5500
389tq/4800
-22tq 2500
+31tq/32hp 5500
+45tq/53hp 6200
+51tq/63hp 6500
ls2 cam 204/211 .525/.525 116lsa
403hp/6100
399/4900
-18tq 2500
+46tq/48hp 5500
+67tq/78hp 6200
ls3 cam 204/211 .551/.525 117lsa
405hp/6100
398tq/4900
-21tq 2500
+47tq/49hp 5500
+73tq/91hp 6500
**Appears Car Craft has a misprint here**
ls6 cam 196/207 .479/.467 116lsa
376hp/5900
389tq/4500
-8tq/2500
+23tq/24hp 5500
+32tq/40hp 6500
lq9 cam 196/207 .479/.467 116lsa
376hp/5900
389tq/4500
-8tq/2500
+23tq/24hp 5500
+32tq/40hp 6500
l33 cam 193/193 .479/.479 116
362hp/5300
387tq/4500
-4tq 2500
+9tq/10hp 5500
+12tq/14hp 6200
ls7 cam 211/230 .558/.558 121lsa
422hp/6300
395tq/5000
-40tq 2500
-19tq 3500
+51tq/53hp 5500
+92tq/115hp 6500
1.8 rockers increased HP 10-12
ls9 cam 211/230 .558/.562 122.5lsa
420hp/6200
393tq/5100
-41tq 2500
-20tq 3500
-2tq 4500
+51tq/53hp 5500
+90tq/112hp 6500
lsa cam 198/216 .480/.480 122.5lsa
389hp/5600
394tq/4800
-27tq 2500
-3tq 3500
+8tq 4500
+37tq/38hp 5500
+54tq/68hp 6500
Crane cams
These are interesting b/c they have very nice gains and didnt give up too much down low.
200/200 .502/.502 113lsa
380hp/5400
401tq/4700
no tq change 2500
+14tq 3500
+15tq 4500
+29tq/30hp 5500
+32tq/40hp 6500
210/218 .551/.551 116lsa
411hp/6000
406tq/4700
-10tq 2500
-9tq 3500
+15tq 4500
+55tq/57hp 5500
+80tq/99hp 6500
224/232 .590/.590 115lsa
442hp/6200
412tq/5000
-25tq 2500
-8tq 3500
+16tq 4500
+69tq/72hp 5500
+105/130hp 6500
The ls2/ls3 cams seem to make nice power w/o too much loss down low. The ls7 and ls9 gained big but gave up alot of tq and probably hp down low. Suprised to see the ls1 cam - nice increase and not too much loss either down low.
353hp/5200
384tq/4300
382hp/5500
389tq/4800
-22tq 2500
+31tq/32hp 5500
+45tq/53hp 6200
+51tq/63hp 6500
403hp/6100
399/4900
-18tq 2500
+46tq/48hp 5500
+67tq/78hp 6200
405hp/6100
398tq/4900
-21tq 2500
+47tq/49hp 5500
+73tq/91hp 6500
376hp/5900
389tq/4500
-8tq/2500
+23tq/24hp 5500
+32tq/40hp 6500
376hp/5900
389tq/4500
-8tq/2500
+23tq/24hp 5500
+32tq/40hp 6500
362hp/5300
387tq/4500
-4tq 2500
+9tq/10hp 5500
+12tq/14hp 6200
422hp/6300
395tq/5000
-40tq 2500
-19tq 3500
+51tq/53hp 5500
+92tq/115hp 6500
420hp/6200
393tq/5100
-41tq 2500
-20tq 3500
-2tq 4500
+51tq/53hp 5500
+90tq/112hp 6500
389hp/5600
394tq/4800
-27tq 2500
-3tq 3500
+8tq 4500
+37tq/38hp 5500
+54tq/68hp 6500
Crane cams
380hp/5400
401tq/4700
no tq change 2500
+14tq 3500
+15tq 4500
+29tq/30hp 5500
+32tq/40hp 6500
411hp/6000
406tq/4700
-10tq 2500
-9tq 3500
+15tq 4500
+55tq/57hp 5500
+80tq/99hp 6500
442hp/6200
412tq/5000
-25tq 2500
-8tq 3500
+16tq 4500
+69tq/72hp 5500
+105/130hp 6500
LS1Tech Sponsor
Seeing the curves would tell the story much better...
Gains are relative...the stock cam had likely nosed way over by then, so just carrying the power a little higher will show huge gains, but I bet the power was already falling off at that point. Peak to peak gains would be nowhere near that big.
Looks like they did some head work too in their testing in 2009. Surprisingly, it didn't add a lot of bang, for the buck.
$1000 heads added 16 hp
$2200 heads added 27 hp
Looks like the cam swap on stock heads is the best bang for the buck.
Last edited by HRHohio; 05-04-2013 at 03:22 AM. Reason: Added date for old article.
Link to article: http://www.carcraft.com/techarticles...e/viewall.html with graphs. Interesting.
Looks like they did some head work too in their testing. Surprisingly, it didn't add a lot of bang, for the buck.
Ahhh, gotcha. Thanks for clarifying.... now I gotta check out the new one.
You guys think the loss of tq with some of the cams will be zeroed-out with some boost?
The thought of losing 20-40lbs of tq in a 5.3 combined with a street gear (~3.42-3.73) just doesnt sound appealing to me. 2500 rpm is sorta below where boost is being made is most cases.
LS1Tech Sponsor
LS2 or LS6 cam in truck
Yes, if you chane to the LS2 camshaft (or the 2001 LS6 camshaft, same lobe profiles) you need to change to the LS6/LS2/LS9 valve springs.
If you have a newer truck you will likely want a newer LS2 camshaft (2007+) that is a single bolt camshaft so you don't have to change your timing gear. If you have an earlier truck with a 3 bolt camshaft to begin with then you want the earlier LS2 camshaft (2005-2006) so you don't have to change your timing gear.
If you have a 1999-2006 truck with a Gen IV engine then you want a 2001 LS6 camshaft because the LS2 camshaft doesn't have the rear camshaft sensor reluctor that you need for camshaft position. You can switch to the newer timing cover, timing gear and front mounted camshaft sensor but that is a lot of added cost that you could avoid if you get a camshaft that has the rear reluctor wheel. Not an issue with most aftermarket camshafts because most aftermarket camshaft cores have the rear reluctor wheel since you can use those camshafts in both the new and old engines (Gen III & Gen IV).
The 2002-2004 LS6 camshaft has even more lift and really should be used with lighter valves, at least if you plan to go to higher RPM (past roughly 5600-6000 rpm).
Just changing from the stock truck camshaft to a LS2 production or 2001 LS6 production camshaft shouldn't require calibration. Your power peak RPM will likely go up and the stock shift points/RPM limit won't fully take advantage of that but you shouldn't have to get the ECM/PCM calibrated due to a mild camshaft change like that. The trucks generally have a 500 to 550 RPM in gear idle speed but the LS2/2001 LS6 camshaft should be ok with that. Some of the newer MT applications run 600 rpm idle speed with similar camshaft profiles and more effective overlap area due to cylinder head flow and valve area.
