Haven't changed coolant in 10 years - What could I be looking at?
So, I will start off by saying I have completely dropped the ball here. Please save the what an idiot posts and things like that. I know I screwed up. Having said that, I am getting my car out of storage in about 2 weeks and am wanting to know what I could potentially have done to the car by not doing this change/flush for so long. Car has 60k miles on it. Any help would be appreciated. Thanks
It's not mine! woo hoo!
Considering that DEXCOOL is an extended life coolant, I can't imagine you'll have to do anything more than a normal flush & fill. You'll also want to take a look for signs that the factory power steering cooler has failed which would mean PS fluid is leaking into the coolant.
I agree with the others, flush with a good coolant flush like prestone super flush, then flush out with distilled water and refill with 50/50 dex cool mix ( you can buy pre-mixed)...
Worst case you might have to throw in a new radiator if there is a **** ton of dexcool mud in there. I had to replace a radiator on a previous car since the owner either used stop a leak or mixed coolants etc...in any event it was a ******* mess, and there was no way I was leaving that radiator in there. I also ended up pulling water pump to inspect and clean as much as possible.
