FTP 104MM Lid - All Items SOLD
Category: Engine - Intake/Fuel
Price: $165
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird
Location (State): UT
Item Condition: Used
Engine: LS1/LS6
LS Engine?: Fits LS Engine
!SOLD! FTP 104MM Lid. Black in color. Seen in the pictures. This thing is in great condition. Sensor will not be included. !SOLD!
!SOLD! I have a FAST 102MM Intake that was ported to match some 243 heads (not for sale) by Total Engine Airflow. The intake has approximately 500 miles on it. The porting cost $175. The FAST 102 writing on the intake is a little bit rubbed away from my working on the car, but obviously this doesn't effect performance. Intake will include gaskets.
As stated above, the intake was used atop 243 Heads therefor this intake is the cathedral port design. !SOLD!
!SOLD! I also have for sale LS2 fuel rails with the spacers that are included in the FAST kit to allow installation on an LS1 with factory size injectors. This is roughly a $200 addition. !SOLD!
!SOLD! 38 lb Injectors that were used with the above intake and fuel rails. I am almost certain I purchased these through Fuel Injector Connection, but I'm not seeing them on their website anymore. They are yellow in color, so I don't know if that helps anybody or not. !SOLD!
!SOLD! I also have a Godspeed 102MM Throttle Body. The throttle body had the normal issues that you see with a Godspeed throttle body. I had to burr out the IAC hole for the sensor to fit. I then had to grind down the throttle stop to allow the throttle arm to rotate enough that the blade will open all the way. Finally I had to drill and tap some new holes and rotate the Throttle Position Sensor for it to function correctly. It may sound like a lot of work, but it was certainly worth it to save the money versus buying a new FAST.
I had holes drilled in the blade, and then patched them with JB Weld so please note that this is by no means a "show-car" quality looking throttle body, but it performs perfect. I just plan on changing setups so I have no use for it anymore. !SOLD!
If you're interested, have any questions, or feel like making an offer, shoot me a PM.
Thanks for looking.
Brad
PM's responded to. I updated the original post to add some 38 lb injectors that I also have been using with the same setup. Thanks to those that have already shown interest.
Updated original thread with sold items. Those items will be dropped off at FedEx on Saturday. Remaining items for sale are the fuel rails with spacers and the FTP 104MM Air Lid. Thanks, guys.
