1993 Formula Firebird Questions
Old 05-13-2013, 09:33 AM
Big D's Z28's Avatar
Default 1993 Formula Firebird Questions
Hey all. Haven't been here in a while since I sold my 01 Z28 a few years ago and have missed it ever since.
I have a chance to pick up a 93 Formula Firebird for next to nothing. Pretty straight and rust free but it has 262k highway miles. The car runs great, and still smokes the tires at will. Optispark was just replaced.
My question is, if I get this car, what are the wear items I should look out for? I really don't know much about what has been replaced on it, so I would appreciate any recommendations you all might have. Thanks in advance.
Old 05-13-2013, 11:56 AM
bufmatmuslepants's Avatar
What's "next to nothing?" Is it an m6 or a4?
Old 05-13-2013, 12:38 PM
Cominus's Avatar
I'm assuming a grand, if he paid more he got robbed
Old 05-13-2013, 12:41 PM
MasterTomos's Avatar
Same weak spots as any LS1 car really. Decarbon shocks are easy to wear out, especially with that mileage.
Old 05-13-2013, 12:55 PM
93M6Formula's Avatar
The highway miles were probably easier on the suspension components but it's hard to say what it would need until you drive it.
Old 05-13-2013, 01:40 PM
I'd budget in outer tie rods, upper and lower ball joints, shocks, control arm bushings, and motor mounts at least.
Old 05-13-2013, 08:55 PM
$500 and it is an A4.
Old 05-14-2013, 07:27 AM
Thats pretty decent. I'd definitely service that trans though.
Old 05-14-2013, 07:28 AM
93-02 f-bodys dont have upper ball joints but otherwise yes, all that stuff.
Old 05-14-2013, 09:09 AM
jaycenk's Avatar
Say what???
3rd gens don't have uppers.
Old 05-14-2013, 09:16 AM
96lt1m6's Avatar
They sure do, I have replaced them....
http://www.classicindustries.com/ima...g/c/cta32a.jpg
Who really cares how much the car was purchased for if OP is happy that's all that matters. Car runs good mod it and have fun.
Old 05-14-2013, 10:08 AM
Originally Posted by jaycenk
Say what???
Son of a bitch.... I was thinking of my 3rd gen..
My bad, Havent pulled the front wheels off my car in awhile and i forgot lol.
Old 05-14-2013, 12:07 PM
I'd change every fluid and poke with your finger every bushing and ball joint and tie rod to see if any are torn. Do fresh ngk tr55 plugs and let her rip. shocks would be a huge help too, I suggest bilstein hds.
Old 05-14-2013, 12:10 PM
Thanks guys. I gave him what the junk yard was going to give him for it. Actually pretty sad that he was going to junk it because it really is not in that bad of shape. It needs a good cleaning and going over, but it could be a decent driver.
I think the trans was replaced, but will check when I get it this weekend. Even if the engine blew up on the way home, a rebuilt 700R4 trans is easily worth the $500 I paid for the whole car.
Old 05-14-2013, 12:16 PM
Thanks! I will check all that when I get it.
Old 05-19-2013, 09:10 PM
I should be picking up the Firebird this week. The current owner told me that he replaced the original Opti Spark when the car just died a couple of months ago and wouldn't restart. He replaced it with an aftermarket unit and since then it has been intermittently cutting out. The computer code reader said that it was Quad Driver Failure?
Anyone know what that means? Is the computer in need of replacement? Is the aftermarket Opti Spark defective? Any thoughts?
Old 05-19-2013, 10:46 PM
Aftermarket opti's are absolute garbage 99% of the time. Replace it (correctly) with an oem unit.
Old 05-19-2013, 10:52 PM
englundjd's Avatar
its prolly a bad aftermarket opti.... the aftermarket opti's have a bad reputation for being junk. but i would check the ignition components out and the fuel pressure
Old 05-20-2013, 01:46 AM
LT11996's Avatar
The sad thing is that if you put a quality optispark on the car, you'll pay nearly as much for that as what you're paying for the car. Hopefully that will solve the it's problems. Post up some pics of her when you get a chance! Good luck with her
Old 05-20-2013, 02:16 AM
AdsoYo's Avatar
The water pumps like to be problematic. I see a lot of threads on low coolant sensor, air bag DERM module, coolant temp sensor, vibrations from the drive shaft... that's all I can think of right now
Quick Reply: 1993 Formula Firebird Questions
