I have this in the fuel section but
I FIGURED I WOULD GET A GOOD RESPONSE HERE.
MY CAR IS A PT88 5.3 STOCK LS2 CAM, 112LB INJECTORS, 60PSI BASE PRESSURE, E85. 4FT 3.5 PIPE OUT THE FRONT BUMPER.
THE CAR WILL START FINE WHEN COLD BUT ONCE YOU GET IT UP TO TEMP THE CAR WILL BACK FIRE, AND I MEAN ITS A LOAD BACK FIRE, AS SOON AS IT DOES THAT, LET OF THE KEY AND HIT IT AGAIN AND BOOM FIRES RIGHT UP 90% OF THE TIME.
i HAVE TRIED LEANING THE CRANKING FUEL TO THE POINT THE WIDEBAND WILL GO DOTS AS IT CRANKS, AND HAVE ADDED ENOUGH THAT THE WIDE BAND GOES 10.0 AND EVERYTHING IN BETWEEN.
GETTING TO THE POINT ITS KILLING MY LIL BATTERY AND HAS LEFT ME STRANDED, ANY ADVICE ON THIS E85 WHEN HOT.
NO WAY TO POST THE TUNE AS OF NOW
So the car starts when cold, once it warms up it back fires? Does it quit when it backfires? Or does it run fine when hot and only back fire when trying to start it hot? Does it start then back fire? Where is your wide band located? How close to the end of the down pipe? Sorry for all the questions but I had a hard time understanding what the car is doing from your first post.
car runs fine once it starts hot or cold.
the car will start fine every time up to about 100DEG ECT.
but anything over 100deg the car will back fire when cranking
back fires once, let off the key, then crank boom fires almost every time
wb sensor is 2ft from the end of the pipe
