Why did my painted LS6 manifold's paint crack?
Old 05-18-2013, 11:57 PM
Austin95's Avatar
Default Why did my painted LS6 manifold's paint crack?
Opened my hood after my first couple of rides since the car has been back together to see that all the paint on my LS6 manifold has started cracking I'm not sure why this happened, I sanded down the entire manifold with 220, then 320. Scuffed with SEM soap and a red scotch brite then adhesion premotered before laying down DuPont 2k primer. Sanded the primer with 600 for base and clear coat. So maybe someone knows what went wrong and can correct me so this doesn't happen again. Thanks
Old 05-19-2013, 06:07 AM
VAformula's Avatar
What kind of paint did you use?
Old 05-19-2013, 10:27 AM
Austin95's Avatar
Dupont gm black. Everything was shot from a spray gun.
Old 05-19-2013, 11:23 AM
1320Chicken's Avatar
Maybe you need a flex agent in the paint. Like you would for a bumper, because I doubt the intake got hot enough for it to fail. Just a guess though I really don't know how much expanding and contracting one of these intakes do.
Old 05-20-2013, 05:33 PM
Austin95's Avatar
Ttt...
Old 05-20-2013, 05:37 PM
LSCha0s's Avatar
Did you use paint rated for high temps? Looks like the primer did not stick.
Old 05-20-2013, 06:56 PM
67goatman455's Avatar
loks like your primer shrunk A LOT. did you let it flash off correctly?
Old 05-20-2013, 07:26 PM
custombluebird's Avatar
don't use the plastic promoter! your going to have to sand it all done sand it with 180 scuff it down , clean it with a dewax and degreaser then lay down some nice coats of primer! if you can see the sand marks after it dries take some 400 and wet sand it smooth. then you can either lay down your base coat or give it another coat of primer that's up to you then it will stick to the plastic and bond together and heat should not effect it!
Old 05-21-2013, 11:54 AM
Austin95's Avatar
No, I was told the manifold shouldn't get hot enough to effect it. I agree, cause it peeled off in sheets, just trying to figure out why it didn't stick.
Yes, I followed the tech sheets. I laid down the primer with about 10 minutes between coats, then it sat for awhile till I could sand and paint it.
Why shouldn't I use the adhesion premoter? I've seen a lot of people use it to help the primer bond. The DuPont tech sheet says 240 for plastic, so will that be good? Could the paint being too thick have been a problem?
Thanks
Old 05-21-2013, 06:51 PM
ZForce1's Avatar
You have to use some kind of promoter, you can't just paint on plastic. What kind of promoter did you use? The bulldog stuff that's in the writup in the sticky? I've seen some primers separate (between itself). Not epoxy primer, though.
Old 05-21-2013, 09:54 PM
"Scuffed with SEM soap and a red scotch brite then adhesion premotered before laying down DuPont 2k primer"
did you clean again in between the soap and promoter?
Old 05-21-2013, 10:18 PM
Austin95's Avatar
Yes, rinsed with dawn and water, dried, wiped with wax and grease remover,and then tach clothed before the premoter.
Old 05-21-2013, 10:49 PM
HotWhipT/A's Avatar
I wanna say the primer was too thick. You don't need much adhesion promoter either. I like Dupont Plas-Stick!
Old 05-22-2013, 01:02 AM
Originally Posted by HotWhipT/A
I wanna say the primer was too thick. You don't need much adhesion promoter. I like Dupont Plas-Stick!
just had a thought...dont most of the aresols say to do a very light coat of adhesion promoter? possible issue?
Wondered about too thick as well, look at third pic, look how much it shrunk up!
Old 05-22-2013, 10:10 AM
HotWhipT/A's Avatar
I know with the Dupont stuff, you have to let the adhesion promoter dry for 25 minutes.
Old 05-22-2013, 05:19 PM
black79transam's Avatar
Boy this has me nervous as I used dupont rattle cans and I'm in the process of painting my intake
Old 05-23-2013, 12:18 AM
had a chat with my boss today actually. he was saying using wax & grease remover on plastic is not a good idea because it pulls the mold release agents and any other oils to the surface. only supposed to use water based stuff or just soap and water
Old 05-23-2013, 02:24 AM
HoLLo's Avatar
That's scary. Hope it never happens to mine. Previous owner had it done in GM Sunset Orange Metallic. I've never painted an intake, but I know, in the past any success I've had with painting plastic, the material had to be highly scuffed.
Old 05-23-2013, 10:14 AM
Austin95's Avatar
I'm starting to think that is a possibility as well. I only put on 3 coats, then wet sanded a good deal off. Either way, it looks as if the primer didn't even adhere at all! I used SEM XXX Adhesion promoter.
Yes they do. On the can it said first coat is a dust coat, then the next coat is a medium wet coat and you let it sit for 15-30 minutes, which I did.
Yes it did. Could the heat have had something to do with that?
Yep, the second coat has to dry for at least 15 and no more than 30.
Hopefully everything holds up for you man, I know how much work they are to do and I assumed that the spray gun would hold up better than a can.
Never thought of that, it could be a possibility. Especially since it appears that the adhesion problem was between the primer and manifold as the paint stuck to the primer fine even when I wiped that down with the same stuff prior to the base & clear coat.
I think that if it hasn't happened you should be good! But I scuffed the **** out of it with 320. If you look at the picture primer to the primer, nothing is shiny.
Anyone else have any ideas?
Old 05-25-2013, 12:51 AM
soooo, in your pics im seeing alcohol and a 3M box. guessing thats 3M adhesion promoter wipes?
Quick Reply: Why did my painted LS6 manifold's paint crack?
