what injectors to get?
i have an ls1 camaro with big cam(228 I/232 E) 600 lift, ported TB, ls6 intake, LT headers, fullly CNC ported 243 heads. I want to change out the stock injectors. what size injectors should I go with?
I have stock injectors on a 231/235 .617/.621 cam and i have stock heads as well that have been milled and hand ported and it all works just fine. If you plan on doing more work then yea get bigger injectors if not do'nt worry about it.
You may want to go larger on injectors if you change to,say,a fast 90 or larger intake with your combo.One choice i used with great results were the ford svo 30lb injectors with the fast 92,but as for what you have,the stock injectors will be fine.
