Trailing arm to accommodate wider rims
I've believe I've held my tongue in the past, but I absolutely hate killernoodle's cut & weld design. The load path and lightning bolt shape just don't sit right with me.
What we need (and I've been trying to convince my friend to make) is a set that utilize bent tubes, similar to older M5's had. I'd be willing to spend up to $400 for a set with quality rod ends or bushings.
The only thing he didn't account for was the durability of his powdercoating process against rocks and the massive load of salt/chemicals sprayed on the road during the winter. The trailing arms don't have anything to physically shield them from that crap. I fixed it by stripping them with a yellow 3M Reloc disc and applying a triple coat of POR-15. If someone is thinking about building trailing arms, remember that you'll need a really thick, hard coating to handle the elements.
I had to do some clearancing with my MAP tailing ams, it would just kiss the front cradle mount washer. I realize the M5 are wider and probably not as thick, but being wider would place them right underneath the mount.
From the pics of killernoodles design, it looks like they may have more rim room available than the MAP design?
Keep in mind that the rear 19x10" Forgestar F14 has a +42mm offset and is probably as close as you want to get to the trailing arm with whatever solution you come up with.
Without MAP trl. arms u would need at least a 1/2" spacer, then your tires would be outside the fenderwell.. looking like a 4 wheeler. I have the arms and spent a fortune getting my OEM rims widened and a 285 is the widest tire one can use SAFELY. a 295 barely fits but not very safe...My rims though are 9 7/8ths...Just get a 4link backhalf Ford 9"..
