Which head gaskets for budget build?
well the 317s muck it up for you
why not use the stock heads, 317s needlessly lower the compression imo
otherwise you could use stock ls1 steel gaskets that are 34 for the pair shipped off summit.
with the larger bore size head i think you will need to run the ls9 or 6.0 head truck gasket. wich are both double the price
