Volant CAI + maggie?
I was messing around with using the Maggie tube vs the Volant tube. I like the slow bend of the Maggie tube vs the 90 degree bend in the volant tube, but the Maggie tube is flat rather than a round tube. Oh well.
I may go with the Volant tube just so I can move my meth nozzle further from the supercharger.
Speaking of METH, do you feel it was worth the expense? I am thinking of adding Meth when I do the 2.7 pulley to help with IAT's. Also what name brand system did you go with? Thanks for any info...
I am using the Devils Own progressive kit. I like it... Easy to install, and I haven't had any trouble with it.
Good luck!
I have tracked my iats during wot and they definitely drop 10-15 degrees max with 50/50 meth water and a 2.6 pulley. But you have to also realize its also preventing the oats from going up drastically too. I'm running the most basic coolingmist kit and tap off my windshield washer fluid reservoir. It has worked great thus far with no issue.
