about to do LS1 -> LS6 PCV
well, i had the heads off to fix some other issues, and figured now is the best time to do the LS1 -> LS6 PCV conversion.
the only part i was not looking forward to was cutting a chip out of the block in order for the new valley cover to fit.
however, i got in there and took a look, and i was pleasantly surprised to find that there is no piece on my block that i have to cut out of the way....i guess that's confirmation that i have an LS6 block!!!
been running Mobil1 fully synthetic since i bought the car (with 11,700 on the clock), either 5w30 or 10w30, depending on whether it's winter or summer.
i usually change it every 5k - 7k, but a couple times it's been longer, maybe 10k
i'm gonna run some seafoam in the oil for 100 - 200 miles once i get it all buttoned up, then do another oil change, hopefully that will clean things up a bit.
It's not mine! woo hoo!
That makes things easier for sure. Not that cutting it is difficult, but when choosing between needing to cut an engine block or not... well, I'm obviously going to choose the latter.
Like mentioned above, I can't believe how much buildup you've got from the oil, though!
When I did this to my c5 I was expecting to have to cut the block because my c5's a 1999 and when I went to install the valley cover I didn't have the provision! Weird stuff, but you'll love how much this cleans up the engine bay.
You cain't do these LS6 VC on GenIV iron blocks can you?
Damonspeed,
Thats nice & clean!!!
Damonspeed,
I don't think the lack of the protrusion is an indicater of an ls6 block, rather that you have an '01 or newer block. Also OP you need to shorten your oil change intervals, 3K is normal and you're extending way beyond that. Probably the reason for the residue buildup. I'm about to do the same swap using fabricated valve covers with no pvc provisions at all, I just need to get air into the crankcase. Good Luck with your swap!! Larry.
Location: Hometown:Mount Carmel, IL Current: Las Vegas, NV
The Scammer Hammer
Yes, 10% of the 2001 LS1 FBody's were 1168's, and 25% in 2002, but that doesn't automatically mean you got one just b/c you didn't have to cut the block. There were about 4 or 5 different LS1 castings if memory serves me correctly.
Also, when I did my valley, I had over 140k on my motor and it loked nice and clean inside. That pic is nasty nasty. 3k miles for oil, I don't give a **** what anyone says. That, and Mobile 1 certainly isn't what it used to be....
