Ported LS3 Manifold, Nitrous Outlet Plate, Drag Wheels/Tires
Category: Accessories
Price: $123456789
Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V
Location (State): AZ
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6
LS Engine?: Fits LS Engine
Drag Pack Setup Wheels & Tires $850
5x4.75 Drag Pack Painted black. Paint chipping on rear wheels. Fronts are GTO Spare wheels with M&H Roadmaster 26x4.5-17. Rears are Weld Racing ProStar 15x10 7.5"bs with Hoosier Quicktime Pro QTP 27x11.5-15. Includes Weld Center caps, 10 Deep open Nuts for rear wheels, Front 1.5" Wheel Spacers to fit inside the fender nicely. Rear control arms need slight modification when used on a GTO. Cost me just over $1500 new 15 Track passes. Cut 1.64 60ft on a 6speed GTO 443rwhp on these.
LS3 Manifold Complete PORTED by BER $550
LS3 Manifold complete with 42LB Stock LS3 Injectors and Rail. Ported by BER; Bare Essentials Racing. Gains are within Fast 102 territory. Comes with all Gaskets. 8K miles on this setup.
Nitrous Outlet Plate $230
Nitrous plate flows upto 400hp. Top Discharge 4 Bolt. Includes an o-ring and longer bolts. ID roughly 92mm. 2k Miles
LS2/LS3 Custom Grind Camshaft $250
This is a custom grind camshaft for anyone with an LS2 that wants LS3 heads. Very streetable with a nice lopey idle. Made 443/418 with unported heads or manifold. Stock bottom end LS2. Roughly 3k Miles on the cam. Looks practically new.
223/239 .610/.623 112
since you are in the seperating mood, would you be willing to sell just the intake manifold? Injectors and rails are not needed for my aplication.
Depends on price of course!
thanks
thanks
LOL, figures, just my luck! Not a bad price either, the manifold itself is $450, I just have no use for the rest.
If you end up changing your mind in the next week or so, let me know, although i may just break doen and buy it through BER anyways.
Yes, a 7.5 backspace fits on the back of a C6, if you have base model rear fenders, they stick out a half inch. Also you need lg drag spindles in the rear, base C6 rear rotors and abutement brackets, a bit of grinding on the caliper and lower control arm to fit a 15" wheel.
I made a write up on Corvette forum about it, and some after pics.
