P1514 - Airflow to TP Sensor Correlation High
Old 06-04-2013, 05:33 PM
PowerAdder's Avatar
Default P1514 - Airflow to TP Sensor Correlation High
Expected airflow greater than calculation. Pcm has an idea of how much air should be entering the engine at given rpm and Throttle angle. I gather its seeing the map sensor go from vacume to nothing, and its going into limp mode affraid that the throttle has opened wide opan. 1 bar DBW SD 5.3 Side mount m112. thinking I should just turn off the code. Anyone ran into this on a dbw SD boosted engine?
Old 06-04-2013, 07:43 PM
edcmat-l1's Avatar
It's very common. Every DBW boosted vehicle needs the P1514 parameters modified. Turning off the code won't stop it from going into REP. It only stops the code from being reported.
Old 06-04-2013, 09:13 PM
PowerAdder's Avatar
Thanks for the insight, Ill try to search around for more information on the corect calibration.
Old 06-04-2013, 10:02 PM
PowerAdder's Avatar
Ok think i see 2 ways to adress this problem. One way is to lower injector size and VE table acordingly to tryand trick the calculation? Another way is to adjust the 1514 table in 10% incraments untill I operate in WOT? Im compleatly new to tuning, and I now see this is quite a newb thing to be asking about, sorry.
Old 06-04-2013, 10:10 PM
9-Second Club
Ed Wright's Avatar
Scale that table by 1.8 and be done with it.
Old 06-04-2013, 10:22 PM
PowerAdder's Avatar
Thanks I'll do that tomarro. I was dissapointed, just got everything finished up went out to start the car sunday and nothing. 4 TB codes, found 3 bad conector pin fitments and replaced the connector. Today I get home to start some tuning and I cant even get into it. Thanks again!
Old 06-05-2013, 07:42 AM
9-Second Club
Ed Wright's Avatar
There is a single value that cures that (allowable accepted error limit) but it's not in your software. About all you can do with what you have there is scale that table.
Old 06-05-2013, 08:31 AM
LS1Tech Sponsor
Slowhawk's Avatar
I've always just maxed the table. Never an issue.
Old 06-05-2013, 09:03 AM
9-Second Club
Ed Wright's Avatar
With what you guys have for software that is about all you can do.
Old 06-05-2013, 10:08 AM
LS1Tech Sponsor
Slowhawk's Avatar
And it works just fine.
Old 06-05-2013, 12:07 PM
PowerAdder's Avatar
Great thanks for the help guys, Ill get it done after I get out of work today. Long 12 hours to wait!!! Hope for 7psi.
Old 06-05-2013, 08:18 PM
PowerAdder's Avatar
Maxed the table and hit the gas a bit. Man this blower is loud. Cant wait to get it out for some wot tuning. Thanks for your help guys!
Quick Reply: P1514 - Airflow to TP Sensor Correlation High
