Do I really need a Tune? And Other small ?s
Hey guys, Im finally starting to get some extra cash for my car.
But Some things need replaced as well so I just decided to upgrade.
Tires- Right now I have a pretty bald set of Yokohama ES100's. Which I like By the way heat them up a little and you can hook pretty decent. I'm probably going to replace them with Nitto 555r's anyone have experience with this tire?
Motor Mounts/ Torque arm bushing -
The stockers are shot! Originally I was thinking a set of Spohn Solids, I decided to Go with the Prothane Kit from Jegs with All 3 mounts. I am concerned that the solids would shake the car to much. As well as a prothane Bushing for the torque arm. How is your experience with these mounts?
Finally the tune-
My car seems to backfire alot I mean not TOO much, but often enough maybe somethings off? I was Considering buying the 150$ tune From frost to see if it makes a difference and if nothing else I'm sure my car will gain a little bit of performance. I just dont want to waste money When I do intend on purchasing LT's. It would be nice to Do The LT's during the motor mounts but I dont have the money for The Hooker 1 7/8s that I want I would've but as you all know our tires aren't cheap. So is the tune worth it?
My Goal is To get the Car bolted up and Cammed Within the next 4-5 months.
Thanks.
Finally the tune-
Thanks.
LS1Tech Administrator
Received 1,492 Likes
If the car is stock and you have abnormal misfires, then a tune is not what you need. Something is wrong with (or affecting) A/F delivery or spark. These cars didn't back-fire (what you are probably describing is actually after-firing) from the factory, so correction of the issue isn't a matter of needing a custom tune but rather performing the proper repair(s). Do you have scanning/data logging equipment? This is going to be an extremely valuable tool in diagnosing such issues.
I do not. What would be the process of elimination? I have a New Fuel Filter I can get some MAF cleaner And plugs. Could it be the coils? I haven't messed with them at all but maybe the previous owner did.
A good cleaning of the MAF and some fresh plugs certainly wouldn't hurt. Many driveability issues can be traced back to dirty MAFs, and it's a free and easy thing to do so that's a great starting point. Another likely area that could cause such problems would be front O2 sensor(s).
Do you have an active MIL (service engine light)? You would need a scanner to read any codes, and there may be stored codes even if you don't actually see the SES light.
You can always throw parts at a car and you might get lucky and solve the issue, but scanning equipment really helps to narrow things down when working on a modern EFI engine.
I haven't drove the car for the last week Because of the issues. I'm going to try and get my hands on a diagnostic tool I really hope it isn't anything too pricey the mounts and tires are already holding me back for awhile. I'd like to do some modding. sigh..
I can offer expirience with the 555r, had them couple months now, track twice and street runs. Hook really well for a mild bolt on car. In fact if they are warmed up a little impossible to spin unless u stand on the brake.
Thanks Guys I really appreciate the help.
