Afr 180s and llyod cam done! stupid oil leak
Well i got my cars together but its leaking at the front of the pan pretty bad. so im off to pick up a oil pan gasket today and seal that up. sounds pretty damn good ill get some videos after i fix oil leak!
anyone just done the oil pan gasket without removing the pan? does it stretch easily enough to go around the outside of the pan? thanks guys
Do you think it would be easier to remove the motor mount bolts and lift the motor up or dropping the crossmember? I only ask because I had a pickup tube fall off so I lifted the motor and pulled the pan all the way off to put a pickup tube retainer on. The motor lifted up far enough to pull the pan, and all I had to do was pull the motor mount bolts.
oil pan gasket was pretty damn easy. but its still leaking. same exact spot. I cant see a leak from timing cover but im assuming its coming from there. hard to see.. prob gonna pull the crank pulley and peak back there. its gotta be from a seal. they are all new ive got no idea.
cant even get my stupid valve covers to seal either. all the hard stuff done so murphy is hitting me with the easy jobs with tons of crap.
