A/C Noob needs help
A/C Noob needs help
Need some help here guys. A/C hasnt worked since I bought the car a few months ago, and its starting to get hot out..
The Air blowing out of the vents is strong enough to fly a kite.
Neighbor had a cheap gauge from auto zone and we put it on. It read in the green safe zone the entire time.
The AC clutch ONLY engages on/off when I turn the AC on and off at the switch.
Air coming out of vent is no more then room temp/warm. Not hot, and by no means cool let alone cold.
So, wtf is going on here. By all means I would think the AC should be working and blowing cold but its not.
Moderator
If there's no difference between hot & cold, but the
line from evap to condenser ices up (or sweats, at
least) then the vacuum control of the diverters is
probably the problem.
You need to see the high side - low side difference
to know whether the compressor is doing its job,
and see both individually to know whether you're
undercharged or perhaps restricted at the orifice
tube.
tube.
i don't know what a cheap gauge from autozone really is, but you really need a high/low gauge set like this to know what's going on
what jimmy was eluding to can also help diagnose things- the output line from the compressor before it goes into the condenser should be hot, and the line from the condenser before it hits where the orifice tube is should be cooler but slightly warm. then after the orifice tube to where it goes through the firewall into the evaporator and the output line from the evap should be cold. the accumulator will also be cold and wet. so just by feeling lines you can somewhat tell if the system is working, if the accumulator isn't cold and wet then the system may be low on r134a. if the output line from the compressor is not hot then your compressor might be shot. if you feel a temperature change anywhere in the line before the orifice tube then you have a blockage.
Thanks for the responses. You will have to forgive my ignorance on what the parts are and what they are called. When I turn the AC on and the clutch on the compressor engages and starts spinning, i can put my hand on the metal canister thats just behind the battery and it doesnt get hot or cold. just kind of stays the same. the lines going into and out of it also stay pretty much the same temp.
I bled some 134 out of the large valve next to that canister and whatever was coming out of it was pretty much just warm air. I would have thought any refridgerant that came out would be cold?
No, it only turns on AND stays on if i turn the **** on. it doesnt cycle on and off, it just stays spinning until i turn the **** to the off position, then the clutch stops spinning
