help please, why doesnt it spray?
Old 06-22-2013, 07:42 PM
JDEP162's Avatar
Default help please, why doesnt it spray?
Ok, got my setup installed, bottle pressure gets perfectly locked at 950-1050, purges out fine, window switch goes green at wot, but no spray. Buddy tested solonoid seperatly and it clicks. All grounds are good. What wud u guess is problem? Im sure its a simple fix and were just missing it. Emailed brandon at n2o outlet havent heard back yet.
Old 06-22-2013, 11:06 PM
metlic53's Avatar
Make sure nothing is plugged up as filtererd fittings etc can plug up. Switch or button?? Make sure they are good.
Old 06-22-2013, 11:30 PM
"MAC"'s Avatar
^^^ Agree I would just recheck everything even though you have probably already done it a couple of times. It can be a pain but check every little wire all the way down to the plugs.
Old 06-23-2013, 03:03 AM
JDEP162's Avatar
yeah me and buddy gona give it the once over this morn, just wondered if there was something I was missing someone cud throw off top of their head.
Old 06-23-2013, 03:13 AM
camscam02's Avatar
Are you trying to test it without the motor running? If so it sounds like the window switch is enabled and it wont fire the solenoids until it sees the lower rpm value that is set on the window switch.
Just a random thought
Old 06-23-2013, 05:36 AM
JDEP162's Avatar
Nah, tried at the track and on the street. Window switch lights green but no fire.
Old 06-23-2013, 07:30 AM
JDEP162's Avatar
Update: just sprayed for the 1st..2nd..3rd..4th time. Im hooked. 100 shot. Quite a kick in the azz. Thanks to all those who have helped with knowledge.
Old 06-23-2013, 08:11 AM
Justins00ss's Avatar
Sweet bud. Welcome to the club. Its all down hill from here. You will be wanting the 200 jets before you know it
Old 06-23-2013, 11:32 AM
"MAC"'s Avatar
what was the problem?
Old 06-23-2013, 07:13 PM
JDEP162's Avatar
Ha, as usualy is, a simple missed setting in the ole window switch. Cyl typ set to o8 only reading 10% of rpms. Set to 00 read em right, fired off perfect. And yeah im already wondering what the 200 will be like. Already shopping for fuel pumps to support it. Def hooked
Old 06-23-2013, 11:22 PM
"MAC"'s Avatar
lol nice glade it was a simple fix! congrats on your set up and def post the new times please.
Old 06-24-2013, 12:35 AM
JDEP162's Avatar
thanks will do, planning to hit the track again soon. all motor was 13.6 so we'll see what she can do on spray
Old 06-24-2013, 12:47 AM
"MAC"'s Avatar
13.6? do you have a LT1?
Old 06-24-2013, 05:19 AM
JDEP162's Avatar
No stock ls1 n/a 13.6. Thought thats about average for ls1 fbody stock with a regular joe driving it down the track, hoping to knock a second off at least with the 100shot now working right
Old 06-24-2013, 01:07 PM
"MAC"'s Avatar
LOL yea get better tires and practice more a stock LS1 with skinnies and slicks should do high 12's like a 12.9 or so (thats the fastest that i had read somewhere). With a 100 shot i dont see why you couldn't get low 12's or high 11's good luck and make sure you practice.
Old 06-24-2013, 06:28 PM
JDEP162's Avatar
Will do thanks mac, il be putting up slips when i can get there
Quick Reply: help please, why doesnt it spray?
