2011 5.0 vs Gto/Wrx & Mach 1 vs Cummins
So e good friends getting some runs in this weekend. Buddy with the 350z traded off for this 3:73 optioned m6 5.0
Gto is a ms3 cam only that put down 432/418 iirc but it is on a stock clutch and it shows. He shut down early every time when he started pulling.
Subie is pretty extensively modded:
lightwight flywheel
cobb lightwight pully
vf39 sti turbo
cobb heat shield, cobb 3 port bcs, FIC 1100cc injectors
sti tmic
cobb sri with post maf silicone hose and cobb air box
amr 3in hard turbo inlet
PnP intake manifold
TGV deletes
Phenolic spacers 8 mill
Grimmspeed PnP stock exhaust manifold with hi flow crosspipe ceramic coated wrapped
grimmspeed EWG uppipe
invidia bellmouth downpipe
cobb cat back with a cutout in it.
Tial 38mm EWG
samco hoses
kartboy short throw kit
gauges I have boost, AEM wideband, oil psi
And a Bolton/dr Mach vs cummins
lightwight flywheel
vf39 sti turbo
sti tmic
PnP intake manifold
TGV deletes
Tial 38mm EWG
samco hoses
I know the cummins is different than the d-max, but look at what I put to the ground and you'll see what I mean.
just saying it would be cool to find out real #s on it. seems to run decent (but the stang seemed slow too).
