obd II port no communication, tested port ideas ? can't get through emissions !
Old 06-24-2013, 11:03 AM
2001firehawk3's Avatar
Default obd II port no communication, tested port ideas ? can't get through emissions !
About to get plates yanked if i dont get this fixed.
00 Trans am no communication with dlc using my launch scanner , emissions station count not communicate as well.
tried my scanner on 2 other cars to verify it works perfect.
I tested the port I have steady 12v power on orange wire,
I tested ground continuity on the 2 ground ports both check ok,
I removed pcm plug and tested data line from port to pcm and have continuity. tried with key on, tried with car running,
yes cig lighter works , yes I checked all fuses.
any ideas would be fantastic.. my brain is saying ecm not putting out data but car runs fine. searched old post without luck
Old 06-24-2013, 11:05 AM
Exeodus's Avatar
Do you have anything else plugged into the lighter ports drawing power while you attempt to use the OBD port, like a cellphone charger?
Old 06-24-2013, 11:11 AM
no i even took the lighter out to be sure nothing was pulling power, scanner powers up so i know I am connecting to the ports power feed
Old 06-24-2013, 11:39 AM
ROCNDAV's Avatar
I use to experience this all the time, trying to connect HPTuners.
I started connecting a battery charger to my car battery, and never see the issue anymore. Coincidence? Maybe.
It's only superstition if it doesn't work.
D
Old 06-24-2013, 11:46 AM
2xLS1's Avatar
Any chance you have an after market alarm or remote start that splices into the purple data wire?
Old 06-24-2013, 04:36 PM
well... wtf.. I put a charger on 10amp, hooked scanner up everything communicated perfect. rode over to emissions station with charger and a cord. the guy looked at me like I was crazy and kept saying no we cant do it with a charger on it.. no com without, convinced guy in office to let me hook up charger .. car passed.. Wow..silly 2 yr old redtop optima and original delco alt putting out 13.8 volts.. Thanks ROCNDAV
Old 07-03-2013, 04:17 PM
ROCNDAV's Avatar
Glad it worked out for you.
Quick Reply: obd II port no communication, tested port ideas ? can't get through emissions !
