turbo choice for stock lq4?
Old 06-25-2013, 07:38 PM
70ssclone's Avatar
Default turbo choice for stock lq4?
I have seen a lot of folks picking different cams for there lq4s but I was wondering what turbo you guys would suggest for my setup, its a 70 chevelle with an 06 lq4 all stock,th400,3kstall,3.73s. id like to not change the cam I figure I can still get a lot of power without one, maybe a t76? or gt45? a set of 60lb injectors and a good tune? id like to not get into changing rod bolts and the like unless absolutely required
Old 06-25-2013, 08:20 PM
samtodd's Avatar
I know its alittle off topic but what mounts and pan you using??
Old 06-25-2013, 08:31 PM
70ssclone's Avatar
haven't bought either yet picking up engine Saturday lol, probably going fbody pan and maybe dirty dingo mounts
Old 06-25-2013, 08:35 PM
willizm's Avatar
Pt7675 will get spooled quick. Have you considered going with a smaller gear say a 3.23?
Old 06-25-2013, 08:47 PM
mrstepheneades's Avatar
S475 with not to big exhaust side so to spool quick be biggest bang for buck and be reliable. 650 dollars. I got the 96mm exhaust turbine and 1.32 ar version and full boost at 4000 on ls1 with cam.
Old 06-25-2013, 11:04 PM
70ssclone's Avatar
Maybe il do higher gears one day, 650 through who? What about a gt45?
Old 06-25-2013, 11:13 PM
55superbeetle's Avatar
I have a gt45 on my lq4, definitely gets the job done for the money.
Old 06-26-2013, 05:52 AM
70ssclone's Avatar
Super beetle, is there anything done to your lq4? What kind of boost levels do you run?
Old 06-26-2013, 06:00 AM
70ssclone's Avatar
Also what gt45 do you have?
Old 06-26-2013, 08:06 AM
9 Second Truck Club
stock48's Avatar
S475 with the 83mm turbine and 1.10 T6 or 1.25 T4 ex housing if you plan to stay 750 and under hp. Go the bigger 96mm turbine if planning on more hp down the road.
Old 06-26-2013, 10:04 AM
831jd's Avatar
what s400 would you run on a 5.3 looking for 850+
Old 06-26-2013, 10:17 AM
I'm on e85 and out of injector on 12 pounds but I plan to turn it up soon. I just have a ls9 cam, pushrods, and dual springs. It's the same eBay gt45 everybody is running.
Old 06-26-2013, 10:20 AM
Forced Inductions.....
They carry garrets too...
Old 06-26-2013, 11:31 AM
99VetteFRC's Avatar
I have a 4.8 in my 70 Chevelle, CTS-V pan and summit mount adapters. I have a pair of Ebay turbos with .63 exhaust housing and they spool pretty quick. I just haven't had the car dyno tuned yet so I haven't figured out how to get the 60' down. I put 3.08s in the rear and the 4k stall heated the trans up so I couldn't drive the car around my hilly neighborhood. I put the 4.10s back in and the car went 12.60@116.97 with a completly stock engine.
Old 06-26-2013, 04:12 PM
Twin turbo c5's Avatar
So many different ways to go. It gets confusing trying to find a turbo. I always go talk to jose at forced inductions he never steers me wrong.
Old 06-26-2013, 04:14 PM
Blackpanther99's Avatar
Yup^ lol Soo many good choices out there really makes it tough.
Old 06-26-2013, 04:48 PM
lsxmalibu's Avatar
Chinese gt45. Done
Quick Reply: turbo choice for stock lq4?
