What is this box under dash can I throw it out
Old 06-30-2013, 12:26 PM
Jason94z's Avatar
Default What is this box under dash can I throw it out
I've googled, searched, looked on shbox. Is there a nice reference thread here somewhere on what can be ripped out from under the dash? I'm doing the HVAC removal and while I'm in there want to throw out as much junk as I can.
So this is the first thing, what is it (airbag computer because it's yellow?) and can I just unplug it and throw it away without wrecking anything?
Thank you
Old 06-30-2013, 02:06 PM
fex77k's Avatar
What do those tags say, usually yellow means an airbag connection.
Old 06-30-2013, 07:50 PM
AdsoYo's Avatar
That's your airbag DERM module. The airbag system won't work without it and you'll have an airbag light on the dash.
Old 06-30-2013, 08:27 PM
Jason94z's Avatar
Thanks. Unplugging and chucking!
Old 07-08-2013, 12:58 PM
Jason94z's Avatar
Ok what about the silver box on the drivers side under the fuses? is that the ABS stuff and can I just unplug and throw it out too?
Old 07-09-2013, 03:46 AM
AdsoYo's Avatar
Would you be able to post a pic? I'm having trouble remembering...
Old 07-13-2013, 07:06 AM
GaryalpUSA's Avatar
The ABS box is toward the firewall high up by the fuses. Same thing. Light on dash no abs.
Old 08-06-2013, 06:49 PM
Jason94z's Avatar
Ok other side this is by drivers feet
Is it ABS? Can I just unplug and throw away? It's that silver box way up there:
Old 09-28-2013, 06:47 PM
Jason94z's Avatar
Anyone?
Anyone?
Bueller?
Old 09-29-2013, 02:56 PM
Hotbird's Avatar
abs.
I pulled all that stuff a few months back...all I left was the vats/tdr, blinker relay, and brake light switch. Lost around 20lb's. Pulling all the wires can be a pita.
Quick Reply: What is this box under dash can I throw it out
