Aeroforce Interceptor
Category: Interior
Price: $190
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird
Location (State): CA
Item Condition: Brand New
Engine: LS1/LS6, LT1/LT4
LS Engine?: Fits LS Engine
Red one not for sale while i send it to aeroforce for a reflash.
Thanks
With a 98 you can simply plug and go. Thats how i currently have it running most of the time. However, it will stay on when turning the car off. So you manually have to unplug it from the obd port.
To have it turn on and off along with the car, you need to either splice it into an ignition accesory or add a new circuit which is what i did with my z28. All you need is a 10amp fuse and a "add a circuit" wire from autozone. They are like 10 bucks iirc and it plugs straight into the fuse box on the drivers side door.
When i get home from work, ill try and get a link to the piece you need. If you decide to splice, you wont need anything else. Just depends on how you want to set it up. Let me know if theres more questions.
You can always use the white face that will come with it.
I dont think im allowed to post links to non-sponsor sites, but heres the picture of the piece thatll make this easier to install. Its under 10 dollars at vatozone.
It plugs into the drivers side where all the fuses are at. And youll need is a 10 amp fuse.
It can read throttle percentage, 0-60, scan and clear SES codes, knock retard, true RPMs, timing advance, coolant temperatures, oil pressure, vacuum, shift light, etc...
PM me for faster response.
