Anyone have pictures of 255/50R16s mounted on stock wheels?
Old 07-01-2013, 04:43 PM
Blu-Zee's Avatar
Default Anyone have pictures of 255/50R16s mounted on stock wheels?
I'm looking at buying a pair of 255/50R16 drag radials for my stock wheels. Anyone have any pictures of a side view of their car where both front and rear wheels can be seen?
I have 245/50R16s on the front now, will the 255s change the stance of the rear any?
I don't want the stance to look goofy or odd with 2 different tires in the front and back. So I just wanted to see if anyone else is running a setup like this and has pictures of their tires on the car so I can get a general idea.
Thanks
Car will be driven on the weekends to and from the track with some passes while at the track.
Old 07-01-2013, 05:01 PM
Mista Blazer's Avatar
I can say i had 17" rims on the back with 315 i moved to 285 when i put my 18" on and to be honest i can not tell a difference on such a low number, now i can tell a difference between 275 and 315
16's would look goofy with 315 i would go with 275 or something meatier in back since they are 16's all around for a stance
Old 07-01-2013, 05:30 PM
2002 blue z28's Avatar
Would 275's fit on a stock 16x8 wheel?
Old 07-01-2013, 06:29 PM
1stPoncho's Avatar
I had 255/50/16 put on all 4 corners of my car. I couldn't tell any difference. The tire height of the 245 is about 25.6" and the 255 is 26". Less than .5" difference. I hope this helps.
Old 07-02-2013, 12:18 AM
Was your tachometer off at all or is the difference to small to affect anything?
Old 07-02-2013, 05:53 AM
bufmatmuslepants's Avatar
Face palm. You mean speedometer? No, you won't notice anything. 255 drag radial or bias ply is 26x10.5, fits great on 16x8.
Old 07-02-2013, 04:49 PM
dailydriver's Avatar
I have 255/50-16 on all four corners as well, and except for a slight sidewall height difference, you cannot tell (but it DOES fill the wheel wells a little better than the 245/50-16s).
I have a Diablosport Predator, so I just changed the overall diameter of the tire in the PCM to take care of the speedometer reading.
Old 07-02-2013, 07:00 PM
My bad, I missed that one. Thanks for the catch.
Old 07-11-2013, 09:57 PM
BandDirector Blk98ZM6's Avatar
When I go to the track, I use my stock 245/50/16 on the front rims and 255/50/16 MT DR's on the rear. I'm attaching pics. My DD duty rims are 18' C5 Z06 rims...
Attached Thumbnails Anyone have pictures of 255/50R16s mounted on stock wheels?-drag-rear-view.jpg   Anyone have pictures of 255/50R16s mounted on stock wheels?-drag-side-view-2.jpg
Old 07-12-2013, 01:45 PM
ybaslo1's Avatar
Here's a BFG street tire in 255/50/16
This is the best one I have of my M/T 255/50/16
I'm taking the car out in a little bit, I'll try to get a close up of the M/T. You can tell it looks bigger,I like the slight bulge.
Old 07-12-2013, 08:43 PM
mjs1012's Avatar
I run my drag radials in a 255/50/16 on stock 5 spokes and they look just a tiny bit bigger on the sidewall. There is not really much of a difference.
Quick Reply: Anyone have pictures of 255/50R16s mounted on stock wheels?
