1st time out 370 PT88 th400
Took my 79 camaro to track last night for some low boost test runs. Was pretty happy with how it ran. All runs were off transbrake @3600 RPM
370 forged 9.0 compression
ls6 cam
stock 241 heads
edlebrock proflow
pt88 no intercooler, single water nozzle just b4 throttle body
th400
PTC 9.5 converter
9"
3.5 gear
28x10.5 slick
1st pass ever left at 5-6psi slowly ramped boost up to 9
I screwed up shifting on 2nd pass was like a 10.45
last pass of the night, left at 5-6psi no ramp 10psi as fast as it could build it
ls6 cam
stock 241 heads
edlebrock proflow
th400
PTC 9.5 converter
9"
3.5 gear
28x10.5 slick
Dang nice runs! Hope my car can 60ft like that, I added the CompEgn bars. My car is a lot heavy than yours 1981TTA. Can you give me the rear wheel size, and backspacing? Look like you got a wide rim, has the car been cut? Your car leave straight, and not all crazy! Love it!
Nice job for your first time out. I will be at midnight madness next Friday running Battle of the Boards which will be my first time out with my new setup. I hope to get some seat time early next week to get a feel for the new transmission setup.
Went back & made 3 more runs last night. All runs with 15psi in the tires off transbrake at 3700 RPM
6psi launch hardly any burnout my best 60ft to date 10psi
didnt build long enough only 4.5 psi launch added a pound on the wastegate got 11 psi
6.8psi at launch added another pound 12psi total
