Highest safe compression ratio for 100 shot?
a friend of mine has a nitrous kit hes selling for a really good price. only problem is my 408 is set at 11:1. how low would i need it to go to safely run a 100 shot and what would be the easiest way to do it?
compression loves nitrous. just take out some spark. 11:1 is no factor. just yank about 4 degrees.
I like spark control via EFI Live's COS5. (costly but best way imo)
LNC2000 seems pretty good too because you can tigger it on/off and won't affect your n/a driving
Not trying to be down on you, but why is your 408 only making 475 hp thru an m6? I would look into that first and then spray it.
Cut that flowmaster off and put a straight thru muffler like a dynomax bullet or a Magnaflow on there. That should get you over the 500rwhp hump and bump the torque up too. The headers an y pipe are not hurting you too bad its the flow master thats killing you. One other easy thing is to throw a cutout on there.
