top outlet FMIC, who's runnin one like this?
Old 07-17-2013, 12:45 PM
GarrettM's Avatar
Default top outlet FMIC, who's runnin one like this?
Treadstone has a top outlet intercooler I've been looking into. The TRST9. I know its real popular with the Vette crowd but who's running it on an fbody. I know the hood latch has to go. Says its capable of supporting 1300hp. Any pics or thoughts with a procharger or front mount single?
Old 07-17-2013, 12:59 PM
MaxxMitchell's Avatar
Hood latch can stay, but you need to notch the radiator core support. I know you can fit a 4" tube over the radiator and under a stock SS hood and WS6 hood. Not sure if the stock flat hoods would clear.
Old 07-17-2013, 01:19 PM
UNDER PRESSURE MOD
The Alchemist's Avatar
That could be interesting to use for a f-body. I got rid of my hood latch in favor of the aero-catches, but I'm not sure how it would work with the hood.
Old 07-17-2013, 01:21 PM
GarrettM's Avatar
Damn I like that. Finished off with a nice radiator shroud that would be exactly what I had I'm mind.
Old 07-17-2013, 03:29 PM
ramairetransam's Avatar
hmm , id like that , someone make me a kit and ill be the guinea pig , like a template and **** and the pipes all bent up .
Old 07-17-2013, 07:12 PM
Tx91z28's Avatar
I run that exact treadstone intercooler, not a 4th gen but it's an f-body:
I do not have hood pins, i use turn buckles and pins through the grill area (which sucks!), i need to build a new latch system
Old 07-17-2013, 10:26 PM
GarrettM's Avatar
Treadstone says it is for the viper, corvette, camaro guys with a core size of 25x9x3.5. I haven't even checked but does that fall in line with the core size normally used on fbodies?
http://www.treadstoneperformance.com...2C+GM%2C+Viper
Old 07-17-2013, 10:27 PM
GarrettM's Avatar
Tx91z28 how do you like that intercooler? Any issues with it that you can think of?
Old 02-05-2014, 08:54 AM
a98ws6's Avatar
Anybody having any issues with this intercooler ?
Old 02-05-2014, 09:00 AM
01boydws6's Avatar
I am pretty sure that is that same one Rick (tntramair)was running with his twin turbo kit, was real slick he had the stock air box lid cover where it came up over the core support
Old 02-05-2014, 10:53 AM
THADD's Avatar
I'm not running that one but I am running a vertical style intercooler from Bell. Here is my set up.
Old 02-05-2014, 11:34 AM
3.8redbird's Avatar
Attachment 437049
Attachment 437050
Attachment 437051
I was thinking of having Bell make me an IC. What size core are you running and what are the before and after run IATs?
Old 02-05-2014, 12:36 PM
vettewreck's Avatar
Ill be running a twin set up with inlets on each side and outlet on top like that. Just the placement works better for my car/setup.
Old 02-05-2014, 06:38 PM
THADD's Avatar
I just got the car running so I don't have any iat info yet, but I will soon. I think the core is 26x12x4.5. When I spoke to Gerrard at Bell he asked for my complete build info, turbo, hp levels, etc and he designed that intercooler specifically for it.
Old 02-05-2014, 07:13 PM
a98ws6's Avatar
THADD, what size inlets?
Old 02-05-2014, 07:58 PM
BTLBABY's Avatar
Has to be 4" piping. Man that sucker is intimidating looking to say the least!
I've heard through out the years, that these vertical style coolers are more efficient than the horizontal designs. Anyone else heard this rumor?
Old 02-05-2014, 09:21 PM
WstSidHomE's Avatar
could you fit it upside down so the outlet faces down and your piping go under the core support and up to TB?
Old 02-05-2014, 09:27 PM
BTLBABY's Avatar
I would think so, just all in how you want to run your charge pipes. Only thing I see might be an issue would be running your cold side right behind the radiator. Heating your piping before it goes in the engine. Kind of like fighting an uphill battle, know what I mean... Unless of course you made a radiator design change or really insulated your charge piping.
Old 02-05-2014, 09:32 PM
wicked z28's Avatar
Good question, that would be great to have another option to run it.
Old 02-06-2014, 05:14 AM
THADD's Avatar
4 inch in and out
Quick Reply: top outlet FMIC, who's runnin one like this?
